#2
If you don't heed the warning about the shavings you risk spending even more on repairs.
03 Turbo AutoStick 107K Cranny |
![]() Quote:
This is pretty straight forward, the shop did nothing wrong and customer apparently refused complete repairs. It sounds like the AC compressor was replaced due to a failed / locked up clutch bearing. Given the same belt runs the power steering, the AC compressor needs to be there. Why did the clutch bearing fail? When a compressor comes apart internally, the clutch can slip and badly overheat the clutch bearing causing it to seize. Metal shavings in the system are pointing to a locked compressor. The customer was then told for the AC to function, more repairs are needed. I'm betting the AC system has a leak and someone kept recharging it ( at home ) but didn't replace oil that has leaked out. Quote:
A bad experience does not always = shop doing something wrong. If you have another shop lines up, go there. Quote:
Do you have any other AC specific repair slips? Quote:
The system will need leak checked first, if the evaporator is leaking, it is a dash out repair. Also, the orifice tube hose will need replaced, system flushed to remove metal and possibly a filter installed to trap metal. ( on most cars, the orifice tune / expansion valve is replaceable but on these cars it is part of the hose. ) |
![]() Quote:
I think a little bit of caution here (and a little money) just might save you a big headache.
Thread Tools | |
Display Modes | |
need some advice | 4SPEED | Wheels, Tires, Suspension | 3 | 10 Feb 2015 09:48 am |
need advice | dickie72 | Turbo Performance | 4 | 25 Feb 2012 04:49 pm |
would like some advice | lookingforhelp | Tech & Performance Forum | 9 | 07 Nov 2010 05:24 pm |
Need advice | air4cefamily | Interior Accessories Forum | 7 | 30 Mar 2008 01:52 am |
need advice please | tomcruz | General PT Cruiser Discussions | 5 | 17 Aug 2004 12:27 pm |
