Lower Intake Manifold Gaskets
Like Tree6Likes
  • 1 Post By ptcruisersteve
  • 1 Post By wwpptc
  • 1 Post By 06_PB6_TOURING
  • 1 Post By chuzz
  • 2 Post By Gkon
Old 08 Mar 2018, 09:52 pm
Gkon's Avatar
Default Lower Intake Manifold Gaskets
Hey there everybody.
I want to change my spark plugs. When I remove the upper intake manifold, there are 4 gaskets attached to the lower intake manifold.
I assume I should replace those, or buy a set of 4, just in case?
This is the part number I came up with. Is it the correct item? I would appreciate your help.
04777873AB
Thanks!
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 08 Mar 2018, 10:38 pm
Default Re: Lower Intake Manifold Gaskets
04777873AB
Thanks!
This is what I found in the 2002 Pt Cruiser Parts Catalog
04777873AB 4 EDZ GASKET, Intake ManifoldCylinder Head To Intake Manifold
It wouldn't hurt to buy a set of four of them in case when you do pull the Intake Manifold you find the need to replace them. I have a new spare set myself.
Gkon likes this.
Old 08 Mar 2018, 11:14 pm
These are all over ebay and other sites of this type. I haven't looked, but I'm sure ROCK AUTO will have these available also. The rectangular ring shaped ones are for the joint between the upper and lower intake manifold units that are stock on the NA Pt's.
https://www.ebay.com/b/Intake-Gasket...668/bn_1361134
Jerry
Gkon likes this.
Old 08 Mar 2018, 11:36 pm
Gkon's Avatar
Thanks, guys.
I did take a look on RockAuto and found them for $5-$6 for a set up upper and lower, rectangular and pear shaped. The also have a cheap set of just the rectangular ones. I'll order a set.
Old 09 Mar 2018, 07:08 am
All you really need is the upper rectangular set. I ordered these from RA in Fel Pro , Mahle or some other big brand. These were something line $ 2 .
These gaskets are silicone and reusable although at this point changing them is worth while.
How many miles on these plugs? Mine had original badly worn out plugs at 162 K so. Since the ignition coil and wires get stressed when run with large plug gaps, I changed the coil ( Delphi, a supplier to GM ) and some generic plug wire set.
Gkon likes this.
Old 09 Mar 2018, 09:18 am
It's a good idea to have a set just in case, Kon. I'm not sure, but I THINK one of them leaking can cause the infamous, notorious P0300 misfire code.
Gkon likes this.
Old 09 Mar 2018, 02:01 pm
Gkon's Avatar
I've had the same plugs in the care since I got it 2 1/2 years ago.
I also don't know how long they were in before I bought the car. That's how I roll, haha.
I found a cheap set of rectangular ones on RockAuto, but wasn't sure if the brand was good. All the other sets include both upper and lower.
Old 09 Mar 2018, 02:02 pm
Gkon's Avatar
I agree, Charlie. I see that they're cheap, so I'll order a set and change my plugs.
Old 09 Mar 2018, 02:42 pm
Gkon's Avatar
Just ordered a set (both upper and lower). $8.22 including shipping, and a .28cent discount using the promo code
rcktpwrd and chuzz like this.
Lower Intake Manifold JimBippy Tech & Performance Forum 4 11 Dec 2016 10:50 pm
Eating intake manifold gaskets? MontieTheMopar Tech & Performance Forum 3 26 Aug 2015 02:08 pm
Changing spark plugs, do I need new intake manifold gaskets? Sea_Shells Tech & Performance Forum 4 23 Jun 2015 08:21 am
Composite intake manifold gaskets 4drturbo General Turbo Discussions 6 28 Jun 2014 05:39 pm
Intake Manifold Gaskets KingKole02 Tech & Performance Forum 9 17 Jan 2006 03:06 pm
