So for context, I managed to cause a break in my '02 PT's shifter assembly (I'm assuming I managed to get some kind of liquid in a place it didn't belong because it wasn't shifting without excessive force when the temperature was below freezing) and have not been able to shift out of park. Taking the console off and inspecting what I could with my extremely limited (0) knowlege, I found the break myself and I'm told that what I need is a replacement shifter assembly. The trouble is that, as I understand, they're no longer in production for the '02 and everything later than that isn't compatible. I've found several '01s and some of them also advertise themselves as fitting an '02, but I don't want to buy one of these things if it isn't going to fit.
So a long question made short, will an '01 shifter assembly fit my '02? As a side-question, how much of a pain is that part to swap out once the console is already taken apart? for reference: ![]() ![]() |
Yes. The 2001 and 2002 use the same shifter for the automatic.
And in truth, you can use ANY auto shifter from any model PT in any other auto PT as long as you swap the whole thing. I put a 2004 ball-style shifter in my 2001 PT. And right now, the Auto Stick GT shifter in my 2007 turbo convertible came out of a 2003 GT. Here's my thread on the upgrade for my 2001 PT which will have the exact same Cobra head shifter as your 2002. The "Handy" Chrome Shifty Swap
![]() Last edited by Handy_Cruiser; 29 Mar 2018 at 05:40 am. |
![]() Quote:
By using my custom shifter balls you can make the round balls fit on your 01/02 cobra head shifter rod without having to replace your entire shifter assembly.
On my 02/03 "DREAM' series balls you simply slide the custom ball onto your shifter rod and tighten the set screw just like you did on your Cobra head Knob. ![]() ALL of the remainder of my custom balls (over 125 different designs) will work on your 01/02 stick by simply drilling one 9/64ths hole, 1/8th of an inch deep into your existing rod. ![]() ![]() I'm literally walking out the door to a Drs. appointment. I'll be back later to explain in more detail. Oh and yes, both year shifter assemblies will work on your PT. Jerry Last edited by wwpptc; 29 Mar 2018 at 09:03 am. |
It should be pointed out that the real cause of your problem is not the broken shifter. The broken shifter is the effect. The cause of the problem is the shifter cable needs to be replaced. The shifter cables outer sheath has either cracked, or been compromised by rubbing on something. This compromise has allowed water to get inside and freeze the inner cable wire to the sheath. This is why it is so hard to shift when the temp drops below zero, and why you broke your shifter.
A complete repair will be to replace both the shifter and the shifter cable. Now that the temps are rising, you can probably get away with only replacing the broken shifter; for now. Next winter you will break the replacement shifter again when you tug on it when the cable is frozen and you haven't already replaced the cable. |
![]() Quote:
![]() 2006 PT Cruiser Base 2.4L NA $250 |
![]() Quote:
Thread Tools | |
Display Modes | |
ECU matching | Kevhead | Turbo Performance | 2 | 13 Oct 2016 02:34 pm |
Looking for after market auto stick shifter assembly | ghostpt | Tech & Performance Forum | 5 | 10 Mar 2015 02:54 pm |
Matching Mud Flap Lettering to Pin Striping | soonercruiser | Exterior Accessories Forum | 8 | 22 Sep 2014 08:26 pm |
Crossover cable adjustment at shifter assembly | DonJuan | General PT Cruiser Discussions | 0 | 13 Dec 2010 07:48 am |
'03 Factory Shifter Assembly | PT Guru | Interior Accessories Forum | 0 | 10 Nov 2002 01:24 am |
