Question about re-clear coating headlight lenses
Like Tree3Likes
  • 2 Post By rob302
  • 1 Post By _PTGT03
Old 05 Apr 2018, 10:30 am
Gkon's Avatar
Default Question about re-clear coating headlight lenses
Hiya PT brethren and sistren,
So, about a year or so ago I got a brand new set of headlights with black interiors for my PT as a gift from a friend. Before installing them, I wet sanded the lenses, then sprayed them with a clear, UV resistant clear coat which was made for use with plastic.
As of today, the passenger one looks as good as new. The driver's side, however, has peeled off on about half the lens. I'm not sure why, as I prepped both lenses the same way and used the same spray on them.
Regardless, I want to redo the driver's side lens. What do I do about the clear coat that's still on the lens? I assume I have to wet sand that all off, then re-wet sand the entire lens, and then spray it again? Does that sound right?
Thanks, guys. You're always a big help.
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 05 Apr 2018, 10:50 am
rob302's Avatar
Default Re: Question about re-clear coating headlight lenses
that is correct. if you use chemicals you'll have a gooey mess in your hands. i've done it both ways. i have used lacquer thinner to remove the clear. sanding is more elbow grease, but is less nasty and also less stressful.
i would guess you applied the clear to the one light too thin and that is why it's coming off, or you didn't give it a super light coat before applying a wet coat.
MJKnight and Gkon like this.
Old 05 Apr 2018, 11:03 am
Gkon's Avatar
Thanks, Rob. You're always a big help.
Old 05 Apr 2018, 09:48 pm
_PTGT03's Avatar
use a scotch brite pad and take out the coating and feather the edges of the peeling until it's smooth.
did you apply a prep solvent before spraying the coating ? something must have got under there
Gkon likes this.
Old 06 Apr 2018, 11:07 am
Gkon's Avatar
The peeling started out as a pinky nail sized area, and is now about half the headlight, so I'd prefer to just remove it all and start over.
Yup, after wet sanding the lenses, then wiping off all that gunk with water and a lint free cloth, I then used alcohol to wipe everything down prior to spraying the clear.
Rear bumper clear coating is peeling 2002_Inca_Gold The Detail Shop 3 17 Jan 2016 09:47 pm
Clear Reverse Lenses F/S StoneWhitePT2 Classifieds: For Sale/Trade 6 22 Apr 2009 10:16 pm
CLear Taillight Lenses kprawdzik Exterior Accessories Forum 3 03 Jul 2007 11:24 pm
Everyday clear lenses gonzomania Exterior Accessories Forum 2 31 May 2006 08:33 pm
Clear Headlight covers gonzomania Exterior Accessories Forum 2 23 Nov 2004 12:33 pm
