Vent Switch Issue or possibly something worse?
Old 05 Apr 2018, 01:30 pm
Vengence's Avatar
Default Vent Switch Issue or possibly something worse?
Not sure how to embed the video in the post but the description of the issue in whole is in the video.
But, My vent switch is either broken, the cable is caught on something or frayed or broken or it could be an entirely different issue or worse than what I think it is. Which I think it's the cable. But, Video in the description.
https://youtu.be/YRyNvv-36No
2008 PT Cruiser LX Inferno Red
Old 05 Apr 2018, 07:10 pm
Default Re: Vent Switch Issue or possibly something worse?
On the back side of the control switch you will find a solid steel cable in a flexible liner. I fixed mine by straightening the kink in the solid wire and loosening the screw attaching the other end to the heater housing, that seemed like the binding point in mine.
A new cable will also work but it may also kink if you tighten the heater housing screw.
Be gentile after you fix it.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 06 Apr 2018, 01:51 am
Vengence's Avatar
Ill look into that. Thanks. I hope thats the issue but something tells me it isnt the cable. I just hope its not the entire air something assembly. Thats expebsive.
Old 08 Apr 2018, 10:31 am
Happy's Avatar
If its the cable refer to the last post. If its a blend actuator,its a (very tiny) motor driven device that opens and closes the valve.
03'PT Cruiser GT and an 05'PT cruiser
Old 09 Apr 2018, 11:54 am
Vengence's Avatar
Adter taking apart the center bezel and looking into it. The cable to the vent selection was bent/kinked. So i straightened it and it works temporarily until i get money to fix it regularly instead of using credit cards. But at least its not a big issue.
UG~! Heater Vent Control Knob Issue 2008 Sarasmiles General PT Cruiser Discussions 3 27 Jun 2014 06:44 pm
Will not start possibly Neutral safety switch byrne_266 General PT Cruiser Discussions 20 07 Sep 2013 02:26 pm
*Possibly solved cranking issue*....Strangely Enough PTCruisn81 Tech & Performance Forum 2 16 May 2013 02:57 am
A/C switch issue? shag Tech & Performance Forum 7 04 Aug 2010 09:52 am
Headlamp switch (w/foglight) B/O issue Katharyn2000 General PT Cruiser Discussions 2 16 Jul 2009 08:16 pm
