Marker light issue
Old 12 Apr 2018, 12:32 pm
Default Marker light issue
2005 pt cruiser dreamcruiser convertible, issue
With front passenger side marker light, the light
Wonít turn on. All other lights including turn Signals
Work including the turn signal on the inoperative
Marker light. Iíve tried grounding the light socket
With negative results. Issue began when that turn signal
Started a hyper flash. So I replaced the flasher and corrected that issue
But the marker light will not turn on. Also the arrow indicator
On the dash stays solid green except when using the turn signal.
Emergency flashers work. Question: does the flasher also
Control the marker lights ? Could I have defective flasher?
Old 12 Apr 2018, 12:55 pm
Handy_Cruiser's Avatar
Default Re: Marker light issue
Try another bulb first. It sounds like the element in the bulb may have broken and is against the other element.
If no joy, try another flasher.
Old 12 Apr 2018, 01:13 pm
LionPT's Avatar
Your other thread: Marker light issue
Marker light issue Pt1327 Testing 5 15 Apr 2018 07:47 pm
Fog Light issue janedoe General PT Cruiser Discussions 9 14 Jun 2013 07:12 pm
fog light issue mattsptgt General PT Cruiser Discussions 3 23 Mar 2013 02:54 pm
Marker/Signal Lights ptcruzin42 Exterior Accessories Forum 2 06 Feb 2003 05:41 pm
