CRICKET SOUND FROM ENGINE ?
Old 14 Jul 2004, 02:27 pm
JGN JGN is offline
Default CRICKET SOUND FROM ENGINE ?
THANKS PEOPLE
I took it to the dealership and it turns out to be one of the belts that need to be replaced..which they have ordered and will replace under Warranty tomorrow free of charge
THANKS PEOPLE
Hi People
I just picked up my 2003 PT Cruiser Classic Edition Monday ..it was used but only 23000 kms (about 12000 miles) and have just found your site ITS GREAT
So I have a question,,for you all,,
When I step on the gas and WHILE increasing speed its sound like the car is being run by a herd of Crickets ? and if you remove your foot from the gas pedal and coasts then no sound ?
Is this just my PT Crusier or do they all make this sound ?
If its just mine ,,how do i correct this ?
my direct email is JGNONT@YAHOO.COM
Thanks in advance for any help
Old 14 Jul 2004, 02:38 pm
Send a message via AIM to jmack
Sounds something that could either be a Belt? Or something in the Exhaust maybe?
About to start work on modding my car and making it look even better than it already is!
Old 14 Jul 2004, 03:48 pm
Agree. Try to isolate the sound - maybe have someone else drive while you listen. Try having someone give it gas while parked while you listen with hood up.
Old 14 Jul 2004, 04:11 pm
Welcom to the forums JGN. I agree with Don, only you drive and have the tech form the place you bought it listen. You may be under warrenty. Good luk, ey.
John
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
Old 14 Jul 2004, 05:21 pm
It's probably the same noise (pinging) that you hear when you get bad gas or the octane is too low or with a stick shift, being in the wrong gear (too high) when your trying hard to accelerate. The PT has a knock sensor but it sounds like it's not working. Get to a professional...if it's doing it all the time, you can damage your engine.
Old 14 Jul 2004, 06:16 pm
JGN JGN is offline
THANKS PEOPLE
THANKS PEOPLE
quote:Originally posted by JGN
Hi People
Old 15 Jul 2004, 09:45 am
Wow. Surprised they replaced a belt under warranty - I thought things like belts, brakes, weren't covered??
Old 15 Jul 2004, 10:03 am
Possibly customer satisfaction seeing it was a "new" used and just purchased. Good for them
Old 15 Jul 2004, 12:49 pm
Send a message via AIM to PTNeo
I just recently had the same problem, mine ended up being since I bough my Pt used, and it was lowered, the previous owner had bottomed out the car raising the radiator support bracket, so when my engine shifts forward on acceleration, the engine would hit the cooling fan.
!$NEO$! 2001 PT Cruizer Limited Edition, Intake vortex, Cold Air intake, Headers, Cherry Bomb with dual lake pipes,Gold Line Lowering Springs, Old school Bomb Rear Lights, Infinity Head unit, 4 TV\'s, Playstation, DVD, 2 MTX mono Amps, 1500 Watts Each, 3 12\'inch Infinity Kappas.
Old 24 Jul 2004, 06:10 pm
JGN JGN is offline
OK IM BACK and so is my herd of crickets under my hood
I took the car to the dealership and they said the belts for the AC alt. etc needed to be replaced,, which they did,,
No noise for one day
Then my herd of crickets came back
So back i go to the dealership again
they then say the tension adjuster on the belts needs to be replaced and they order the part I wait 4 days for it then it comes in, back to the dealership I go.. and its installed ,,,no noise
The next morning guess what the herd is back,, BUT ,,as soon as the
engine warms up after a short drive,,no noise
So does anyone one else have this sound when they first start the car ?
is it normal ? am i just being to picky and should live with it ? or ???????
Thx in advance
JGN
THANKS PEOPLE
THANKS PEOPLE
Hi People
Engine idle sound and thud/pop when powering off KingKole02 Sound and Security Forum 10 04 Jul 2009 09:34 am
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
tapping elacua General PT Cruiser Discussions 3 27 Mar 2006 06:53 pm
Complete Engine Swap TaylorMade General Turbo Discussions 35 05 Jan 2005 03:34 pm
