Yet another post about those stupid radiator drain plugs.
A few months ago I drained the radiator. Needed an adjustable wrench to loosen and re-tighten, but otherwise uneventful. Today I drained the radiator again. This time I was able to use my fingers to loosen. But it seems I backed it out too far: a good half an inch maybe. Now it turns freely in both directions. I can't seem to get any "bite" on the helical threads or whatever. I've tried tapping lightly with a hammer in each of 4 90 degree positions, no go. I'm about to try tapping lightly in each of 8 45 degree positions. If that doesn't work I'll probably try removing the plug completely and get an inspection mirror up there to see what's going on. Any tips? Anyone know the "o'clock" position for closing or re-inserting the petcock? I hate to really start pounding on it Last edited by mysterylectricity; 22 Apr 2018 at 05:21 pm. Reason: solved |
Oooh excellent photo, I was hoping for one
![]() I got it back in about 5 minutes after posting. I noticed that as I turned and pushed, it just felt different in different positions. As I recall I turned it to the point where there was the least friction, and could sort of feel it go in just a hair's breadth, like it was rocking in a bit of a valley. A few light taps with the hammer and it went in, then a twist or two CW and it cinched up. No leaks (yet). |
You are supposed to twist it 1/4 turn, then the fluid should drain out of the downspout except with my 09, the radiator came with the downspout molded shut as did a replacement that I bought last year. So the only way to drain the radiator is to remove the petcock which unless you know how it's constructed, is very easy to mangle. As Handy shows, the petcock has a hook to prevent it from being removed intuitively because it wasn't designed to be removed, only opened.
If you happen to mangle your plug, go to OReilley or another parts store that has the "Help!" brand carded parts. It's only $5 compared to $8.45 from Chrysler. ![]() The other option is to remove the lower drain hose but be sure to get the spring clamp on correctly when reattaching. If you close the clamp a little too far out, the hose may seem attached firmly but the hose will pop off when the pressure rises to 18 psi and you'll loose all your coolant. Guess how I know? |
Thread Tools | |
Display Modes | |
Radiator Drain Plug | quest | Tech & Performance Forum | 3 | 12 Aug 2015 03:27 pm |
radiator drain plug | wood38 | PT Cruiser Convertible Forum | 2 | 18 Aug 2013 01:40 pm |
Radiator drain plug | bogaz | Tech & Performance Forum | 12 | 11 May 2012 01:54 pm |
How to replace radiator drain plug? | hotdog789 | Turbo Performance | 2 | 22 Feb 2010 11:57 pm |
Radiator drain plug | Mapper | Tech & Performance Forum | 16 | 15 Jul 2009 08:06 pm |
