Mysterious leak
Like Tree2Likes
Old 30 Apr 2018, 06:45 pm
Default Mysterious leak
Hi everyone, I'm making this post only a month after spending over $1000 at the mechanic. Today, my neighbor told me my car was leaking, so I looked, and everything on the passenger side is wet. There is red/pink fluid all where the serpentine belt splash shield and part of the oil pan. The trans fluid is still perfectly full and the car seems fine. I was thinking trans fluid, but the transmission is on the driver's side. Any ideas?
Old 30 Apr 2018, 06:57 pm
LionPT's Avatar
Default Re: Mysterious leak
Coolant...you need to take it back to the shop that did the work.
What did you have fixed for a $1000..??
Old 30 Apr 2018, 07:11 pm
The work done was : radiator, chemical cooling system flush, rear brake cylinders, radiator hoses. I did see on the receipt that he used red coolant. I'll inspect and see what I can find
Old 30 Apr 2018, 07:21 pm
Azrak's Avatar
If the fluid is on the serpentine belt, not the timing belt area, I would think maybe power steering leaking but just not enough to start making a racket yet. Check your power steering fluid level, it uses ATF+4 transmission fluid.
2005 Touring Convertible - 2.4L I4 DOHC 16V Turbo Engine - 4-Speed Automatic Transmission.
LT. Almond Pearl Metallic Clear Coat - Black Cloth Top.
Cloth Low-Back Bucket Seats - Dark Slate Gray.
Old 30 Apr 2018, 07:50 pm
I checked, but I really can't see anything with the cramped engine bay. The coolant is significantly less pigmented than what ever is leaking. I also checked power steering, but the leak is a little lighter and doesn't smell like power steering fluid. I don't know what to do now?
Old 30 Apr 2018, 08:25 pm
rckstein's Avatar
It might just be residue left over from the work.
I would pressure wash the entire engine area and then wait for it to come back, then you also might get a better idea of where it's actually coming from.
Old 30 Apr 2018, 08:33 pm
LionPT's Avatar
Check the lower radiator hose..coolant can leak into the lower the radiator support & run into the splash shield.
I would take it back & have the shop do a coolant pressure test....JMO
Old 30 Apr 2018, 09:08 pm
I'll make sure to check the hose later. I'm sure it's not left over from the work, because the old coolant was brown orange and milky from all the rust, and the new leak is continuous.
Old 30 Apr 2018, 09:24 pm
If it is not a loose hose clamp another possible area to look is the thermostat housing. It my be a problem with the housing gasket or the housing itself may be cracked. Check the hose to the reservoir as well
2002 Limited Edition 2.4 Auto with 177k Miles
Old 11 Jul 2018, 05:25 pm
Exclamation Re: Mysterious leak
Hello everyone, it's been a while and the leak still persists. The car still drives as it usually does and here's the thing, none of the fluids have lowered! I have collected some of the leak into a cup and it is red. The color matches power steering fluid the most, but unlike power steering fluid, it has no smell. The fluid leak drops near where the AC compressor is. I wasn't even able to see the leak from under the car, because the splash shield was blocking. I don't know what to do anymore
Mysterious non start. LnRCarrs Welcome New PT Cruiser Members 3 02 Apr 2016 09:16 pm
Mysterious coolant leak. Pressure test? Gkon General PT Cruiser Discussions 38 29 Aug 2015 05:38 pm
Mysterious overheating. Fallen9510 Tech & Performance Forum 6 31 Jan 2015 07:38 pm
A foul & mysterious odor.. PawsToDream Tech & Performance Forum 11 07 Jun 2014 01:26 pm
Mysterious Rattling Noise Gone Hoosier Tech & Performance Forum 16 25 Aug 2013 08:09 pm
