AC Compressor Clutch Removal Help
  • 1 Post By ajhockey3
Old 30 Apr 2018, 07:31 pm
ajhockey3's Avatar
Default AC Compressor Clutch Removal Help
I bought another AC Compressor, im trying to swap clutches so I don't need to evac the entire system, however the compressor I bought the clutch won't come off, I pulled hard as I can, I rented a clutch removal tool (None of the bits seemed to be compatible with compressor)
the bad clutch fell right off when I took the bolt out previously, But it was also pretty badly broken
Need advice! its getting warm and the rest of my AC system works
2006 PT Cruiser Base 2.4L NA $250
Old 01 May 2018, 09:44 am
ajhockey3's Avatar
Default Re: AC Compressor Clutch Removal Help
Alright update, there is two threads in the compressor front, one is for the bolt on the clutch that holds it into the pully, and a larger thread inside the clutch that Is used for removing it, I went to a fastener place, found the specific bolt, tightened that puppy down until it pushed against the pully and pushed off. I have no idea what size bolt this is, the lady at the place I got the bolt at gave it to me for free, with no receipt so.
rob302 likes this.
Clutch Or Compressor? ajhockey3 General PT Cruiser Discussions 3 06 Apr 2018 02:32 pm
5 Speed trans removal,, clutch replace info? drumrooster Tech & Performance Forum 10 04 Feb 2016 10:47 pm
PT Cruiser AC Compressor Clutch BEARING Part#, any help? engelhart Tech & Performance Forum 1 07 May 2014 05:39 pm
Clutch removal Garrett Tech & Performance Forum 10 04 Mar 2014 07:31 pm
01 Clutch oddity-possible clutch master cylinder? opelenvy Tech & Performance Forum 6 17 Sep 2008 03:35 pm
