How many 5-speed manuals?
Like Tree13Likes
  • 1 Post By the3dgm
  • 1 Post By rcktpwrd
  • 2 Post By rob302
  • 2 Post By the3dgm
  • 4 Post By the3dgm
  • 2 Post By the3dgm
Old 03 May 2018, 05:34 pm
Default How many 5-speed manuals?
I picked up another PT Cruiser, Photos coming soon, a '04 base 5-speed beer can! Body is in great shape, the top priority, and it drives out fine.
This was the only stick I looked at that had the 1-2-3-4-5-R shift pattern, where 5th was above Reverse, and not a R-1-2-3-4-5, where Reverse and 5th were both up and to the left and right of 1st and 3rd,respectively.
So, how many 5-speeds came in PTs?
svtnos likes this.
Old 03 May 2018, 06:50 pm
rcktpwrd's Avatar
Cool Re: How many 5-speed manuals?
Only two manual transmissions were offered. The one you have, same as mine with the n/a engine, a t-350. And the Gatrag 288 with the GT/turbo engine. I believe the Gatrag has reverse to the left of first gear...
the3dgm likes this.
Joel
www.rcktpwrd.com
Old 03 May 2018, 06:52 pm
rob302's Avatar
Default Re: How many 5-speed manuals?
i think quite a few were 5 speeds. since manual trans vehicles are harder to sell, they usually cost less as well. my pt was only 250, and if it were automatic, i wouldn't have bought it. the only thing i really hated about it was that it had a hydraulic clutch pedal. i love cable operated clutches. turn a nut and set it to your liking. so simple and trouble free.
the trans you have is available geared a few different ways. i think the one in my 2002 had slightly lower highway rpm
svtnos and the3dgm like this.
Old 03 May 2018, 07:28 pm
Thanks guys, just pulled the build sheet and it does say it has a T350.
It seems to have rather short gears in 1st, 2nd and 3rd and it is very quick through them. Fourth is what I would expect and fifth is like overdrive, the only reason you know the engine is running is you are still moving and holding your speed. Though I could tell I tested the A/C while in 5th. . . it worked fine!
wwpptc and rcktpwrd like this.
Old 03 May 2018, 10:22 pm
As promised. . .
2010 Classic, 2.4l n.a. auto, 'The Blue Beast' and 2004 Base, 2.4l n.a. 5-speed, Graphite Metallic Clear Coat
Originally a California car
Old 04 May 2018, 12:23 am
My '01 is a 5-speed manual, easy shifting.
I don't know what percentage were manual vs. automatic, I assume around 8% or 10% but this is just a guess.
Old 04 May 2018, 02:33 pm
rcktpwrd's Avatar
I highly recommend replacing the factory shifter bushings with aftermarket poly bushings. I have the Booger bushings in mine and it is one of the best things I have done to the car! It takes all the slop out of the linkage and you get nice feel going through the gears!
the3dgm likes this.
Joel
www.rcktpwrd.com
Old 04 May 2018, 03:02 pm
Wish I had a 5 speed my GT is an auto. Still a fun daily though if I ever blow er up I'd like to try to swap for a Getrag, anybody ever heard of someone doing it before? When I buy another (yes, WHEN) I'll search high and low for a 5spd, hard to find around here it seems. I'd be curious as to how many they made too.
Channel C.G.E. - 2004 PT GT (Mopar Stage 1) dipped "Black & Blue," 2007 "Daily Cruiser" Rally/WRX inspired build
Old 04 May 2018, 03:43 pm
Thanks for the tip rcktpwrd, I'll do that.
I was looking for a turbo with a stick also and actually found three! Unfortunately, with all three they needed the timing belt, etc. changed, had thousands in body repair work, the best about 1000 to 1500 dollars worth, the worst, half the body was a bad bondo job! One needed a clutch, one an exhaust, etc., etc. on top of what they wanted for the cars they just were not worth the cost, at least to me.
I'm happy with what I ended up with. It's fast enough, it rides much better then the GT with it's sport suspension, tracks true, but it is a beer can! The only power are the windows, however, it does have a CD radio with six speakers and it sounds great!
Monday I'll take it to my mech and have them go over it and see if there is anything that needs fixed now.
rcktpwrd and channelcge like this.
04,07 service manuals Joes06ptcruiser Tech & Performance Forum 2 16 Sep 2017 10:54 pm
Owners manuals, which one do I need Moparman440 General PT Cruiser Discussions 1 29 Sep 2013 08:25 pm
Parts Manuals chris15 Tech & Performance Forum 3 08 Feb 2013 09:32 pm
service manuals RODRUN General Turbo Discussions 1 14 Oct 2003 12:57 pm
