Alternator??
  • 1 Post By JoeX
Old 06 May 2018, 07:28 am
Default Alternator??
Hey guys, Cruiser down...
I saw my battery light come on at night. In morning she started up.
I noticed windows slow, radio turned off. I pulled into an autozone and it stalled.
I think it’s the alternator. Do I have to lower the engine to replace it?
Old 06 May 2018, 08:53 am
Default Re: Alternator??
I would suggest a battery load test first.
If battery checks out good I would check the battery volt to see if you are getting 14 volts or above with the engine running. If you are getting 14 volts or higher I would check the battery cable connectors. If you are not getting 14 volts or higher I would suggest you check all the wires going to the alternator first. On the 2001 & 2002 Pt Cruisers it is common for the wires to drop down to the half shaft and short out the wires going to the alternator.
What year is your Pt Cruiser?
Old 06 May 2018, 01:15 pm
I’ll have a load test done now that it’s charged. It’s an 2001. I had crank position sensor issues in the wiring I fixed.
Everything wire wise looked fine not too long ago.
Old 06 May 2018, 01:34 pm
the crank position sensor on 2001 is just above the oil filter on the back side of the motor.
The wiring harness sometimes is not secured and rubs on the right axle causing problems with charging because of broken wiring. Check this first.
Handy_Cruiser likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 06 May 2018, 08:54 pm
Got the car home finally, bought a new battery.
12.5 volts drove home 5 miles. 12.4 engine off
Turned engine on 12.1 volts. So it’s for sure not being charged by the car.
I hope it’s just the alternator, not the wiring.
Old 06 May 2018, 09:45 pm
I would suggest making sure the wiring has not dropped down shorting out the wires first before looking at the alternator. Also make sure the wires going to the alternator are secure. Some members have found the wires loose or not making contact.
Old 07 May 2018, 04:10 am
I'd say Chrysler alternators last 100K to 150K plus miles. I just got a rebuilt alternator from Advanced Auto for my truck. Seemed like a good piece. I took the end cover off. New brush pack and bolts etc.
According to the 2006 manual, the right axle must be removed to get the alt. out. There is a fusible link bolted to the starter terminal that goes to the alt. output terminal. I'd look at that for signs of heat or corrosion.
Old 07 May 2018, 08:28 am
ajhockey3's Avatar
Mine lasted 140,000KM, pretty sure its fairly normal. Doesn't look fun to replace, Have to remove the driveshaft.
2006 PT Cruiser Base 2.4L NA $250
Old 08 May 2018, 10:34 am
Took it to a really accommodating shop near me.
The battery cable wire broke off at the terminal clamp where it bolts onto the alternator. I still went ahead and put the new alternator in.
Anyone want to buy my used, working alternator? Ha ha
Old 08 May 2018, 09:24 pm
_PTGT03's Avatar
better to keep it in a spare parts box in your garage, you never know when it will be useful
Looking for a h/o alternator ShakeMyShifter99 Tech & Performance Forum 5 12 Apr 2018 03:29 am
alternator? turbomax General PT Cruiser Discussions 13 11 Jul 2017 02:18 pm
alternator rokinbenji05 Tech & Performance Forum 4 01 Sep 2011 06:30 pm
H/O Alternator jonnbr Sound and Security Forum 0 18 Nov 2009 02:08 am
Alternator Mark Tech & Performance Forum 0 13 Feb 2002 05:46 pm
