Vent Select Fix
Like Tree3Likes
Old 07 May 2018, 06:04 pm
ajhockey3's Avatar
Default Vent Select Fix
Now that I got my AC running good, I kind of want to have the vents work right, currently only my defrost works
video:
https://www.youtube.com/watch?time_c...&v=wZYh_BXTWWY
I know i need to replace the cable, I cannot find the part # for the cable, or if they even sell replacements. Can't find on rockauto too.
And has anyone done this before? Can't find any guides on how to fix. Thanks )
2006 PT Cruiser Base 2.4L NA $250
Old 07 May 2018, 06:13 pm
LionPT's Avatar
Default Re: Vent Select Fix
As far as I can tell, it's 5179479AB
Old 07 May 2018, 07:46 pm
ajhockey3's Avatar
Thanks, Any guides on how to replace? didn't see any on youtube
are parts pricing fairly universal through dealers? I have no experience buying anything from a dealer,
Found this from a dealer
https://parts.villagechrysler.ca/p/C...BoC1zEQAvD_BwE
Old 07 May 2018, 08:33 pm
LionPT's Avatar
No, prices can vary a lot.
I don't think that's a bad price, as long as you can pick it up...no shipping cost.
ajhockey3 likes this.
Old 08 May 2018, 07:56 am
ajhockey3's Avatar
that dealer is about 5 hours from me, Just found that on the googles,
Going to try to bend it before replacing it, its not the money, its that I'm lazy and don't feel like tearing apart my dash.
if this is the kink here, I got my fattest set of plyers trying to straighten it out, if this doesn't work, might get it some help from mr heat gun.
Looks like this might have happened before, someone has been in here, on the right side of the console you can see someone pryed it off with a screw driver at some point. Its a 7 owner car so shit happens
Handy_Cruiser and Carnut like this.
Old 10 May 2018, 07:29 am
ajhockey3's Avatar
Well that ****ing sucked, Took me an hour and a half to replace, fiddled with it, cable wasn't the problem, the blend door is seized or something, even manually with my hands changing the linkage, i couldn't get the vents to work
Old 10 May 2018, 01:20 pm
I am in the exact same boat. 2007, and mine is also stuck on Defrost (which is fine I guess, works for winter).
But I am not even sure where to start with replacing the bent cable.
You were never able to get it working again?
Old 18 May 2018, 10:08 am
ajhockey3's Avatar
I replaced the cable but it kinked instantly
if your going to replace the cable ill let you know the steps.
the linkage inside the dash is seized on mine, anyone know what part its called? or how to replace?
Old 19 May 2018, 07:03 am
JDK52's Avatar
Have you disassembled the cover from the right of the air box (to the left of the removed glovebox).
The mechanism for controlling the air flow doors can be examined there.
When ours was purchased it suffered a similar condition.
I was almost resigned to having to remove the unit to make the repair.
Luckily, with the side cover removed the "frozen" defrost door was able to move after somewhat gentle torquing in both directions.
If my memory serves, it is the arm most to the rear of the car in orientation.
The "cam and track" arrangement that engages/synchronizes the control doors can become misaligned complicating matters, so look at that also.
The cover is responsible in keeping the peg in the channel - and it is only up to the task in the best of conditions.
On our defroster control door there was a tendency to stick in the defrost position.
As a prophylactic, an appropriate sized rubber block was cut and glued in a fashion that buffered the defrost door control arm when positioned in the full defrost position.
Our situation was complicated due to a previous event where someone had done the practical joke of pouring Mylar confetti into the defroster vents so as to have the surprise of a confetti shower when engaging the system.
Such lack of love and respect is what makes them the used car bargain!
Old 19 May 2018, 08:20 am
ajhockey3's Avatar
ill take the door off and post picutres on Monday when i'm free. I put a new cable on, and I didn't pay much attention to how it worked. If I remember correctly the gear that had the cable attached to it was fine, but it attached to another gear ontop of it, that was L shaped? and it snapped into the main gear and that wouldn't move freely and when I forced it to move air still didn't come out of the normal vents.
I'm nervous to try to jam it into another gear, defrost works really well, and I'd rather have just defrost then nothing.
Looking for A/C vent knobs????? a1500ram Interior Accessories Forum 6 28 Aug 2007 01:49 pm
A/C vent knobs yogami Interior Accessories Forum 2 07 Oct 2003 12:24 am
