Does the Rad fan effect AC?
Like Tree5Likes
Old 09 May 2018, 04:51 pm
ajhockey3's Avatar
Default Does the Rad fan effect AC?
After I thought my AC leaked out, the garage took it in, Did some digging and found it worked fine when they brought it in, first thing in the morning but stopped working after a minute, turns out the radiator fan is bad, and the system builds pressure (I was turning it on when I turned the car on), but no air moves past it, its builds too much pressure and shuts off. However they claimed it worked OK when they put a shop fan infront of it. The low speed fan is broken but the high works.
Does this make sense? Or can they not figure out what was wrong with it?
Not experienced with AC, would like to know before I drop $200 on a fan.
And the Dye from "Manually" putting it in, because there machine wasn't working.
2006 PT Cruiser Base 2.4L NA $250
Old 10 May 2018, 08:05 am
Default Re: Does the Rad fan effect AC?
In short yes. No fan the a/c will run at high pressure and not work correctly. The high speed fan should turn on when the a/c turns on. It's all computer controlled but don't know if the low speed fan has any effect on the a/c. The fan should be replaced (assuming it's the fan at fault). Remember to assume makes an a$$ out you and me. You may also have more than one issue, fan and a/c.
If you don't trust your mechanic get a second opinion.
Good Luck!!
Old 10 May 2018, 03:01 pm
rsrocket1's Avatar
From the service manual:
However, I notice that the high speed fan goes on anytime the A/C is turned on so this may have changed since the writing of the manual.
Old 10 May 2018, 06:05 pm
ajhockey3's Avatar
The garage I took it to was pretty sure the AC high pressure built too much at idle, and causes it to shut off, I also have a pending OBD2 port for the high pressure switch, Low speed is burnt out so replacing anyways. Hoping this is my last issue!
Old 11 May 2018, 12:55 am
My experience has been that the AC will not work unless there is a fan in complete working order.
$200 for an new, installed fan is cheap.
Old 11 May 2018, 02:39 am
The high speed radiator fan is turned on when the high pressure switch of the refrigerant system reaches ~300 psi. The fan turns off when the pressure drops below 235 psi.
I find the A/C On section of the chart to be confusing.
Old 11 May 2018, 05:43 am
ajhockey3's Avatar
Ended up finding a new fan for $65 and installing it myself
Old 11 May 2018, 10:00 am
rsrocket1's Avatar
Good for you. Some people don't know how or aren't able to do this but as you found out, it's a pretty easy task. Just make sure the plugs are securely fastened and not left to dangle and get worn down by rubbing against anything.
Opinion:
The fan is a weak spot in the PT. It was obviously meant to have a 100k mile lifetime but they typically fail before that especially with low mileage PT's driven by people who tend to drive short distances on surface streets and put very few miles/year. Unfortunately the small compartment engine cannot run in city traffic without the fan running a lot which wears out the brushes. A brushless fan would have solved all this but when you're pinching pennies on the design, you don't care what happens 10 years down the road.
Old 11 May 2018, 01:44 pm
ajhockey3's Avatar
Opinion:
My cars at 166,000km, the fan has been replaced at somepoint, looks like with a junkyard one as it's got markings on it, and the two toughest screws are missing!
Old 11 May 2018, 04:38 pm
rsrocket1's Avatar
Crazy isn't it? Stick a junkyard part which has one of the shortest "lifetime" lifespans in the car. Almost like putting in used rotors or wheel bearings from a junkyard.
Tokicos/OEM ground effect pic Busa_Powered General PT Cruiser Discussions 8 09 Oct 2012 01:07 am
Effect on Value o8bluept General PT Cruiser Discussions 6 09 Jul 2010 03:52 pm
Water Effect Spray Painting DIY L0WL1FE General PT Cruiser Discussions 7 09 Jul 2010 12:50 pm
This could effect all of us... COP TZER General Turbo Discussions 51 22 Nov 2003 03:04 pm
