O2 heater circuit issue
Old 09 May 2018, 09:29 pm
Default O2 heater circuit issue
I've had an intermittent p0032 and p0038 code that just popped up again. This time the cel started blinking. I got a p0204 also. I checked the upsteam o2 heater circuit for resistance and it checked out. With the engine running and the O2 unplugged I checked voltage across each heating wire on the harness side of the connector. One read 9.5v the other 0.5v (both white wires). It is my understanding that they should have been 12v. Does anyone have a wiring diagram for 2004 PT turbo of the O2 connection to the pcm? Any other suggestions? Thanks.
Old 10 May 2018, 03:11 am
Default Re: O2 heater circuit issue
When I had the p0038 code it was a bad/broken ground on the left fender.
Copper wires corroded and seemed tight but I found them broken after removing them from the eyelet.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 10 May 2018, 04:31 pm
You may get lucky and find it is a loose wire or bad ground, so definitely check them out. But, most times, these codes are signaling a failed PCM. I speculate that the high under hood temperatures caused by the turbo, and because the PCM is so very close to that turbo, cause the PCM to fail. It seems that the O2 circuits fail first.
But definitely check your connections and grounds first.
Heater Issue ajhockey3 General PT Cruiser Discussions 2 08 Jan 2018 09:34 pm
O2 sensor heater circuit NPTW Tech & Performance Forum 4 02 Jun 2017 01:21 pm
o2 heater circuit problems Aristo99 General Turbo Discussions 2 04 Oct 2012 07:12 pm
Heater Blower Motor Issue sscanlan General PT Cruiser Discussions 5 30 Aug 2011 10:50 pm
Issue with ac and heater when turn dial on. steph66 General PT Cruiser Discussions 6 06 Feb 2011 07:40 am
