2006 PT P0882, P0700 Non Turbo Recommended Trouble Shooting Sequence?
Like Tree16Likes
Old 13 May 2018, 11:00 am
Default 2006 PT P0882, P0700 P0032, P1603, U0101, NT Recommended Trouble Shooting Sequence?
Days ago, I just bought a 2006 automatic, Non Turbo, base model, with a TIPM, and it suddenly lit the MIL and is showing codes P0882 and P0700. It is showing no driveabilty issues, no limp mode, but it has shown some random indicator problems, all the cluster warning lights flashed once while running and the theft alarm light has been on longer at times, and while running. I also notice that some of the entry exit arm/disarm settings have randomly changed. Horn sound and headlight on settings now seem to be active, although I didn't change them, and there were instances where my OBDII scanner couldnt seem to link to the ecm. Codes have been cleared once and reoccurred, but not immediately.
I have done as much research as possible here and elsewhere, but I don't have a shop manual or electrical diagram yet, so I was hoping for a link and any opinions on where this leads, or where to start, Battery, Wiring, TIPM, ECM/TCM?
Any suggestions from experienced PTC owners would be appreciated.
Old 13 May 2018, 03:13 pm
LionPT's Avatar
Default Re: 2006 PT P0882, P0700 Non Turbo Recommended Trouble Shooting Sequence?
I'll PM you a link for the 2006 Manual.
First think to check is your battery & ground wires.
This set is to the right of the air box...don't just look at them, pull them off & check them.
Old 13 May 2018, 03:48 pm
P0882-TCM Power input low
P0882 is set when there is less than 3.0 volts present at the transmission control output circuits located in the PCM when the Transmission Control System request the power up of those circuits.
Possible Causes:
Transmission Control Circuit short to ground (T15)
Transmission Control Circuit open (T15)
PCM
As LionPT posted check the group of ground wires first.
If the ground wires have good contact I would suggest checking the wiring and contacts at the solenoid pack under the battery support plate. One member fixed the P0882 by cleaning the solenoid pack contacts. We need to make sure the TCM is communicating with the PCM properly.
pjfent likes this.
Old 13 May 2018, 04:12 pm
Thanks for the replies.
Battery terminals were good. I tested battery and alt voltages and they seemed OK. At 12.x and 14.x V, and I tested those two grounds for resistance between them and the negative battery terminal with a multimeter, and they seemed OK to me, able to reach 0 ohms with some digging. Do you think I should still take them off and check anyway?
Still getting some random erratic behavior along with the codes, the theft alarm light stays on past the start for an extended period on some starts and goes out like normal after a few seconds, at on, on others.
Old 13 May 2018, 05:09 pm
LionPT's Avatar
Many users have posted the same only to remove them & find broken wires at the connectors.
pjfent likes this.
Old 13 May 2018, 05:15 pm
Another member posted this information
Originally Posted by Sexygomer View Post
Here is the Alldata disg procedure for this DTC
pjfent likes this.
Old 13 May 2018, 05:30 pm
Thanks. I'll make sure then.
LionPT likes this.
Old 13 May 2018, 09:24 pm
Thanks for the procedure.
I checked the grounds as LionPT recommended, and cleaned them up slightly, but I don't think they are the culprit. The wires are intact and there was only slight corrosion. I also gave the PCM connectors a little wiggle, after the battery + was disconnected for a while. The code reoccurred soon after reconnecting the battery, after that and cleaning the grounds.
I guess from here checking wiring is next.
Old 19 May 2018, 11:27 am
Well I thought that I would give a little update on this problem for others that may be having similar issues.
Not resolved yet, but it is manageable. I realized some of my new car, ignorant assumptions were wrong. The car is actually going into limp mode when the P0882, P0700 codes are set, my unfamiliarity with the car and low speed, speed bump residential test zone just masked it. I also realized that some of my dash light/immobilizer issues seem to be due to one bad key. It will start the car at times, but at others it seems that the chip is not being read, or losing com in the ignition. The other key seems to be normal.
I also realized that this code(s) is set on start up and that if it does not set then, the car will run normally for as long as you want, until you restart. It does not seem to set once running, and if it doesn't set within a minute of start all is good.
I also noticed that clearing codes or disconnecting the battery cable does seem to reset the problem instantly and it will often run for days without re-occurring.
I found that getting to this potentially problematic, under the battery tray, connector is not as easy as it seems in the postings. Although getting the battery and battery tray out is simple, this connector is attached to the battery support underneath, out of sight, and there is little cable slack, when disengaged from it.
IMO it seems that removing the Battery support for access/inspection is probably best, if not absolutely necessary, and access to the front support bolts is not easy at all. I had to give up with the limited tools that I had with me.
Let me know if you see any other PT newbie errors in the above assumptions, or have any further suggestions, though.
Old 10 Jun 2018, 11:27 am
Well you were right LPT
I also started to get a consistent P0032 code (Upstream O2 sensor heater circuit high), and this led me back to those drivers side grounds again. So I took them both completely apart and found three or four marginal connections, then said screw it, I might as well redo them all to eliminate them, while I am there, and did.
The P0032 code went away immediately, and stayed gone, and my primary problem stayed off for a couple of days, but did reappear.
So here are some of the distinctions that I have made so far:
The P0700 and P0882 codes are highly variable and do not seem to be related to any typical usage parameter. They do not seem to be affected by mileage or heat, or vibration.
When set they can often be reset for hours or days again, by clearing codes or taking the battery cable off for a while. Although they do persist through code clearing at times.
The different keys are irrelevant to the problem, but it is always precipitated by an immobilizer light hanging on flashing and often an accompanying chime. On rare occasions a no turn over/no start will also occur, but it will turn,start and run on a second attempt.
The engine doesn't die after a few seconds, as I understand it should with a bad key reading. The immobilizer light will go out on start, but typically the P0700, P0882 codes will set as Pending right away, and limp mode will follow. Often when this situation is happening, my scan tool can not clear codes, and comes back with a communication error, when attempted.
At other times none of this happens for days, and all is completely normal.
I have also had the temp display missing, at times, then back, on restart, and yesterday the speedometer zeroed, while in limp mode, and returned on restart. At other times none of this happens for days, and all is completely normal.
Yesterday I drove 100 km out of town and back, had maybe 6 starts, no problems, no codes, parked it half a day. When I came out to leave immobilizer/chime/codes. Tried driving and clearing. Unable to get the codes to stay cleared, limped home, parked overnight with pending codes on, with battery disconnected. Today normal start, no codes, normal drive.
I keep coming back to the PCM as the most likely explanation, but any other opinions would be helpful. SKIM somehow maybe?
trouble code p0882 limp mode eli PT Cruiser Convertible Forum 6 02 Nov 2016 03:20 pm
Trouble shooting help Turbo5351 General Turbo Discussions 6 22 Aug 2016 04:50 pm
2006 pt cruiser touring sedan p0882 p0700 theholdenz Tech & Performance Forum 1 01 Jul 2015 08:25 pm
Radiator Fan Trouble shooting. Casper30224 Welcome New PT Cruiser Members 13 03 Apr 2014 05:09 pm
cooling fan trouble shooting freegdr General PT Cruiser Discussions 8 29 Jun 2011 09:50 am
