Trans issue
Old 13 May 2018, 07:21 pm
Default Trans issue
I just put a 2005 pt non turbo motor and trans in my 2008 pt cruiser. Had to swap some sensors but other then that everything went well until I noticed an extra plug for the trans.. my trans does not have the input for it but the 08 trans does.. what is this wire for and do I need it? Trying to figure this out b4 I go any further
Old 14 May 2018, 01:28 am
Default Re: Trans issue
I swapped wiring harnesses once when I was having issues (it end up being the PCM and grounds) with my 2006 NA Automatic. I noticed it had an extra plug near the trans, never connected it to anything, everything worked.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 14 May 2018, 03:38 am
The 2008 trans is the VLP [variable line pressure type]. That is what the extra wire is for. I don't think the 2005 trans [non VLP type] will work in your car. The shifting process is different.
Old 14 May 2018, 08:56 am
I would suggest checking with the salvage dealers for comparability of the transmission.
2004 gt turbo trans issue.. deltas69 General PT Cruiser Discussions 16 01 Feb 2017 10:48 am
PT Cruiser Touring Possible trans. issue? jturpen569 General PT Cruiser Discussions 14 31 May 2015 12:26 am
03 GT trans issue...weird one CrewChief Tech & Performance Forum 18 26 Aug 2012 06:22 pm
05 manual trans driveability issue bmcia Tech & Performance Forum 2 28 May 2012 07:52 pm
2001 Auto Trans Issue's TWEAK General PT Cruiser Discussions 4 02 Dec 2010 12:40 am
