Are The Oxygen Sensors The Same?
  • 1 Post By rckstein
Old 15 May 2018, 11:00 am
Default Are The Oxygen Sensors The Same?
Looking to change both oxygen sensors and was wondering if they are the same sensor or if they are different? thanks
Old 15 May 2018, 11:35 am
rckstein's Avatar
Default Re: Are The Oxygen Sensors The Same?
On my PT, they are different, the length of the lead is different, as well as the connector.
Call any dealership, and using the VIN to your PT, they can tell you what yours has.
wwpptc likes this.
Old 15 May 2018, 02:25 pm
PTpreacher's Avatar
Mine were both different as well. One longer than the other...and one was made by Bosch. and the other by Mopar. PTpreacher
Old 15 May 2018, 03:06 pm
If you are buying aftermarket sensors, depending on the brand, most of them use the same sensor for both locations. They simply used longer wire on both and put a plug that will fit in both locations.
If you are buying dealer parts, then they probably will be two different part numbers, with plugs that will fit only their designated positions.
We have speculated that they are actually the same sensor, but with different lengths of wires, similar to what the aftermarket does, since Chrysler also used the PT downstream sensor as an upstream sensor when used in a non-pt car. Probably as a cost cutting measure since wire equals lots of money when you consider the numbers of vehicles being produced. For the aftermarket, the cost of the wire and plug is already built into the cost of the sensor so it is different.
Anyway, why are you looking to swap the sensors? As a maintenance procedure or better fuel economy?
Old 15 May 2018, 03:50 pm
MycKee: I am changing them because an engine code po137 keeps coming on after the car sits for a couple of days.
Where are the 2 Oxygen sensors located? DrummerJoel Exterior & Interior Styling 6 13 Mar 2017 11:59 am
Oxygen Sensors for 2004 Turbo mycar Tech & Performance Forum 10 21 Aug 2014 06:14 pm
Wideband Oxygen sensors texasjoe Turbo Performance 2 07 Jul 2014 11:54 am
Oxygen sensors denmclaugh General PT Cruiser Discussions 3 10 Jun 2012 02:52 pm
Oxygen Sensors Myron12 General PT Cruiser Discussions 5 14 May 2008 11:58 pm
