tensioner replacement
Like Tree9Likes
  • 3 Post By RickinPA
  • 1 Post By Carl48
  • 3 Post By rsrocket1
  • 1 Post By ajhockey3
  • 1 Post By Carl48
Old 16 May 2018, 04:42 pm
Default tensioner replacement
Has anybody replaced the tensioner for the drive belt for the power steering and AC compressor? Want to know if it can be accessed easily from the right wheel well behind the splash shield.
Old 16 May 2018, 04:58 pm
Default Re: tensioner replacement
Yes, you get to the tensioner through the right wheel well by removing the splash guard. Here's a tip I posted some time ago. It's a snippet from replacing the power steering hose.
Removing the tensioner isn't too bad. A short 15mm socket on a ratchet loosens it. But you can only crack it loose, backing the bolt out will jam the socket-ratchet against the frame. The trick is to crack the bolt loose, remove the socket-ratchet, take the socket off the ratchet and then use just the socket (by itself) on the bolt to back the bolt out with your finger tips. Assembly is the reverse.
Old 16 May 2018, 05:59 pm
Thanks for the tip !
Old 16 May 2018, 07:19 pm
Schlyder's Avatar
Yes. I just did mine about a year and a half ago. It was pretty easy.
2002 Limited Edition
2.4l NA
auto trans.
242,000 km
2 project.
2001 Limited Edition
2.4l NA
auto trans.
155,000 km
Old 17 May 2018, 03:40 am
easy is good
CRUZ likes this.
Old 17 May 2018, 07:58 am
rsrocket1's Avatar
If the pulley is squeaking, you may need to only replace the pulley wheel itself. Taking it off requires the same craziness with no clearance, but the pulley wheel is cheap at $28 locally vs the entire tensioner assembly at $40 mail order or $70 locally. Plus my aftermarket pulley was narrower than the OEM which made installation much easier. You can see that the new pulley is wide enough for the belt, but isn't so wide that it hinders putting the center bolt back in like the original.
Old 17 May 2018, 05:10 pm
ajhockey3's Avatar
If it is the bearing though, you can pound a new one in for even cheaper.
Carl48, if the bolt goes right against the frame, take a some wood, or a hockey puck, and put it on a jack and raise the transmission, it will tilt the motor side ways and should give you the clearence.
Carl48 likes this.
2006 PT Cruiser Base 2.4L NA $250
Old 18 May 2018, 03:49 am
Great idea !
He shoots ! He scores !!!
Old 18 May 2018, 07:41 am
ajhockey3's Avatar
Originally Posted by Carl48 View Post
Great idea !
I used to use wood, but when jacking up a car with wood all the cracks always made me nervous, Hockey pucks are soft enough to not punch through the pan, but tough enough to not make noise. I got one I cut a slit in, so it fits perfectly on the pinch weld
Old 18 May 2018, 03:44 pm
We must think alike. Took a hockey puck to the machine shop and had a friend mill an approximate 5/16" x 5/16" groove across the face of it. Fits nice into the pinch seam.
ajhockey3 likes this.
Manual timing belt tensioner vs auto belt tensioner Bandit2014 Tech & Performance Forum 9 11 May 2016 01:57 pm
OEM tensioner jondickson General PT Cruiser Discussions 1 09 Oct 2012 03:57 pm
tensioner help!!!! tbcrusier Tech & Performance Forum 11 08 Jun 2011 08:08 am
Replacement Tensioner for 01 cruiser Candace General PT Cruiser Discussions 1 23 Feb 2009 02:15 am
