Rpm problem
Old 19 May 2018, 12:05 pm
Default Rpm problem
I have a 2003 gt automatic , the car started picking up speed , if while driving at lets say 40 mph and I slip it into neutral the rpms pick up from 2000 to 2500 , sometimes it feels like it"s on cruise control, I did replace the throttle position sensor and it seems a little better, any ideas ?
Old 19 May 2018, 01:17 pm
Default Re: Rpm problem
Sounds like a vacuum leak to me. Did you knock a vacuum hose loose on the back of the engine? There are a few in the area of the throttle body and as they age, they get brittle. I'd take a look at them.
Old 19 May 2018, 04:54 pm
took some carb cleaner and sprayed around the vac lines , throttle body area, and then the intake manifold and nothing showed up on top the engine, theirs no missing or hesitation
Old 19 May 2018, 05:55 pm
How is the rpm's at an idle?
If you have a vacuum gauge see what the vacuum is doing as you increase the rpm's.
Old 19 May 2018, 05:58 pm
hangs around 1000
Old 19 May 2018, 06:10 pm
i would suggest checking to see if the PCV hose is loose at the intake manifold and also the PCV.
Old 19 May 2018, 07:04 pm
hoses looked good and I tested the pcv valve and it's working, I did run a test with the cruise control and after I set it the car gradually picks up speed, especially if I'm going down hill, I haven't had any engine codes
Old 19 May 2018, 09:09 pm
oldthom's Avatar
Could be the exhaust be blocked or the converter is shot.
2004 LE 64K
Old 20 May 2018, 06:06 am
I'll get that checked out
Old 24 May 2018, 04:40 am
I'd replace the PCV valve with a factory part, especially on a turbo car.
Check for a vacuum leak at the brake booster.
Starter problem? Relay problem or others? postbeauty General PT Cruiser Discussions 3 22 Jun 2015 05:52 pm
2001 PT Auto Trans Problem and Engine Rev Problem johnwwjr Tech & Performance Forum 4 18 Apr 2015 10:00 am
AC problem became Overheating problem BilltheBrewer Tech & Performance Forum 1 23 Jul 2014 11:31 pm
Window problem and AC problem kaypriest Tech & Performance Forum 30 04 Jul 2014 07:42 am
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
