Wiring harness replacement
  • 1 Post By JoeX
Old 25 May 2018, 10:17 am
Default Wiring harness replacement
I have been having trouble with my o2 heater circuit. Have been getting a high voltage code for both upstream and downstream. It is for a 2004 pt with 2.4 turbo. I see two fixes. Can someone help?
1. I run a new ground after the heater circuit wires for the o2 sensors join together, If the code persists then try and track down the pin that the other side of the heater wires go to. I don't know how to tell what pin the heater wires go to on the ecm.
2. I purchase the complete engine wiring harness from mopar for the 2.4L turbo 2004. But I can't find the right one.
https://mopar.chromedata.com/NextGen...99381/62811679
Old 25 May 2018, 10:38 am
Default Re: Wiring harness replacement
Check the ground from the O2 connector end with a meter. Or just do the repair
My o2 heater circuit high was bad grounds on the left fender,
Copper wires corrode like your copper drain pipe in your sink.
Cut the smaller wires off the eyelet bunch leaving the heavier gauge wires on the eyelet.
Purchase some new eyelets, Strip the wires back about 3/4 inch and attach two of the smaller wires to each new eyelet.
I soldered mine. No more problems.
Good luck.
rob302 likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 25 May 2018, 10:40 am
I would suggest going to the dealer and asking for the part number after providng the VIN number to your Pt Cruiser. You might have to go to 2 or more dealers as some of my dealers won't give out part numbers in my area.
On page 131 it gives information on the different part numbers for engine wiring harness.
http://krutbox.net/Parts/CD4/02-05/04pt.PDF
Old 28 May 2018, 02:35 am
does no one remember, This is a common issue with Turbo PT's.
Your PCM is fried buddy.
The heat from the turbo melts the internals and it always fails with a O2 heater circuit code.
bet if you replace the PCM it fixes your issue.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
New Wiring Harness Plymal Tech & Performance Forum 1 05 Oct 2015 03:47 pm
Wiring Harness mnso123 Classifieds: Want To Buy 0 07 Jul 2012 02:09 pm
wiring harness BeagleDad Classifieds: Want To Buy 0 09 Dec 2011 02:05 pm
Wiring harness 99PlyNeon General PT Cruiser Discussions 4 19 Jul 2011 11:09 am
wiring harness? PTcruzer02 General Turbo Discussions 1 26 Jul 2009 06:08 pm
