Climate control cable - selector 2007
Old 27 May 2018, 01:11 pm
Default Climate control cable - selector 2007
Iím at my witís end. I need to put in the new control cable but I canít figure out how to get in there. The autozone page talks about removing the center air duct, but that wonít come out. I know there is an easy way to do this... does anyone have a link to a video that shows this? Do I need to remove the radio too? Thanks!!
https://www.autozone.com/repairinfo/...96b43f8075b40a
Old 27 May 2018, 04:58 pm
ajhockey3's Avatar
Default Re: Climate control cable - selector 2007
is this for the vent selection? I just did that one I can tell you how, I don't know how to do the other cable
2006 PT Cruiser Base 2.4L NA $250
Old 27 May 2018, 07:33 pm
Yep, that is the one. I took a picture this afternoon of the vents. They seem to be held in place at the bottom. Hopefully the picture helps make sense. Getting the glove box out is easy, and I would even be happy just switching the vents to face until winter. And thanks!!
Old 27 May 2018, 10:32 pm
LionPT's Avatar
AFAIK, you don't have to remove those ducts. The cable doesn't go high.
Remove the control center & follow the cable.
Old 29 May 2018, 09:19 pm
I canít get my hands in there... if I can find a video, I might be able to talk one of the kids through it?
Old 01 Jun 2018, 09:23 am
ajhockey3's Avatar
Remove center console (Two screws in vents)
Remove center console can leave it hanging
Disconnect cable from the knob.
Remove glovebox.
Remove the thing that holds the gloveback cable, its like a T25 Torq bit.
There should be a white tab with a 6MM end on it. that holds the cable in place.
Remove it
Remove two other 6MM bolts at the bottom and top of the plastic where the cable goes into.
Should be able to pry it back, and replace the cable.
Replacing climate control cables discovering06 Tech & Performance Forum 0 14 Dec 2017 02:48 pm
Vent control cable - 2007 PT LE siamese_retriever General PT Cruiser Discussions 2 07 Jul 2017 06:55 pm
A/C cable for vent selector? Mashuu Interior Accessories Forum 0 11 Oct 2015 09:57 pm
Climate Control Light ID meder2487 General PT Cruiser Discussions 4 21 Jan 2011 04:55 pm
Cruise control Cable bquik Tech & Performance Forum 0 30 May 2010 08:22 pm
