Overcharged A/C
  • 1 Post By JonN
Old 29 May 2018, 06:36 pm
Default Overcharged A/C
I thought I may have been out of refrigerant so I went to check the level and it read overcharged what should I do.
Old 29 May 2018, 07:04 pm
JonN's Avatar
Default Re: Overcharged A/C
There's a variety of reasons that could be happening, which other members will probably be able to explain much better than me.
The questions I have are
1) is the compressor clutch engaging?
When I got my timing belt changed, my mechanic discharged the AC lines. I went to recharge it afterwards and got the same reading you are, I think it was around 100 PSI.
My mechanic forgot to plug in a connector to the compressor underneath the car, when I plugged it back in, I got the appropriate reading and was able to recharge no problem.
2) is the radiator fan coming on when you turn on the AC?
2016 Jeep Patriot Sport 2.4L 6 speed auto 97k
NRS brakes and energy suspension bushings
Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 29 May 2018, 07:15 pm
JonN's Avatar
I've also never seen a DIY AC kit that had gauges for both the high pressure and low pressure lines, only the low side.
In my opinion you may need someone with both gauges to accurately diagnose what is going on. This is something I'd leave to a shop with the proper diagnostics if it becomes complicated.
#LoudLife
Old 01 Jun 2018, 09:26 am
ajhockey3's Avatar
If the clutch isn't engaging try jumping the AC pressure switch on the dryer. Seems like a common problem with PT's
2006 PT Cruiser Base 2.4L NA $250
Old 01 Jun 2018, 01:16 pm
Hi pressure switch could be holding the compressor from running
Did you pump the system down before adding freon
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Jun 2018, 03:53 pm
ajhockey3's Avatar
Thats all that was wrong with my AC system, $32 switch from Napa
Ac overcharged PTloser32805 General PT Cruiser Discussions 8 07 May 2016 02:03 pm
A/C reads overcharged, blows hot air, compressor not engaging bahamapt Tech & Performance Forum 13 16 Sep 2014 09:14 pm
A/C blowing warm then cold idling & overcharged!!! 66CUDA Tech & Performance Forum 65 05 Apr 2010 09:07 am
