watts link
Like Tree2Likes
  • 1 Post By Carl48
  • 1 Post By Carl48
Old 05 Jun 2018, 03:50 am
Default watts link
Replaced the watts link bellcrank on my PT only about 13000 mi ago. Noticed recently some noise in the rear when travelling over the bumps in our lousy roads. Upon inspection, there seems to be a little wiggle between the bellcrank and the through bolt. Is that normal? Can't remember how tight it fit after replacement.
Old 05 Jun 2018, 06:44 am
Default Re: watts link
I never had that noise with mine. Did you torque it to spec? And before you ask, I DO NOT know the torque specs, okay?
Old 05 Jun 2018, 10:53 am
Yes...
Old 05 Jun 2018, 09:17 pm
It's probably bad again. there shouldnt be angle wiggle when it's good. Are your shocks in good working order. If another part is worn, it could cause premature wear.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 05 Jun 2018, 09:30 pm
tnx, will check them out.
Old 08 Jun 2018, 06:53 am
Well, couldn't stand the rumbling noise in the rear any longer so got carried away yesterday. After about a 5 hour thrash on the driveway, the shocks, watts link bellcrank, and both upper and lower arms and ball joints all got replaced. There was some wear in the bellcrank (after only 13K mi) but the original arms didn't look too bad. The shocks were wasted. The PT is 08 with 76K on the clock. Rides good now, no noise.
rcktpwrd likes this.
Old 10 Jun 2018, 10:15 pm
044400's Avatar
Could be rear sway bar if your car has one
2004 Turbo Lite Purchased 4 $400
Old 11 Jun 2018, 03:44 am
mine has no rear sway bar
044400 likes this.
Broken Lower link of watts link buffie Wheels, Tires, Suspension 1 09 Mar 2015 06:41 am
Watts Link or Watts Link Bushing? Judhudson Wheels, Tires, Suspension 17 06 Apr 2014 05:54 pm
watts link jamestown478 Wheels, Tires, Suspension 17 05 Jun 2013 03:14 pm
watts link terrylittlejohn Tech & Performance Forum 12 25 Jan 2011 07:00 pm
Watts link bolt ado63 Tech & Performance Forum 2 11 Oct 2010 04:36 pm
