I know this topic has been beaten to death but I've tried searching and get conflicting advice... comments... help!
Problem: car displays a code of p0480 (low speed fan error) Problem. If the air is on, when starting the car it will throw a P0480 code within a minute or two. If the air is off, it will take about a mile or two before throwing the code. Car does NOT overheat and air seems to work, though cooling suffers sitting at a light. Checked both relays and they seem to be ok. I also jumped the contacts in the relay sockets and the fan seems to run normally. The fan comes on shortly after starting the car if the air is on but I'm not sure what speed it's running at. I really need accurate fan operation information. Should the low speed fan come on immediately when the air is turned on? If not, when? How does the computer know that there is a problem with the low speed fan? I'm wondering if I really have a fan problem , or a false code error? Can the fan be bad and still run when run when tested manually? Replacing the fan/relay asm is an expensive 'guess' I'd prefer to be able to prove the problem is there. Also the fan asm is N/A from Chrysler ![]() Car is a 2006, touring convertible turbo with about 97,000 miles on it. Thanks for any help! |
I would suggest checking the radiator plug contacts to make sure you are getting good contacts. Some members have come across radiator plug contacts that have been arcing or one of the pins have been pushed in.
If at First You Don't Succeed - Try, Try Again |
deac; the air conditioning high pressure switch will turn on the high speed radiator fan relay. This takes a few seconds. You should easily hear the fan running when it is on high speed. The fan is barely audible when it is on low speed. Sticking a straw into the fan blades [be careful] or a dab of white on a fan blade might help.
The factory fan assy. had a 'fan module' mounted at the bottom of the radiator. It contained the relays. Aftermarket fan assys. usually had 2 relays mounted to the passenger side of the radiator shroud. When you jumped the fan relays you should have heard the 2 speeds of the fan. Cooling should not change while sitting at a light. My recommendation is to clean/check/and lube the three grounds on the inner fenders. There are 2 on the left fender and especially the 1 on the right front fender which is difficult to see and get to. ---- All are 5/16" hex head sheet metal screws. |
PT06,
Thanks for the help. Do you know the relay control signal sequence? Does the computer turn the low speed fan for low speed and then turn it off and switch to the high speed relay to activate it or does it turn BOTH relays on for high speed? I don't know what the low speed fan is actually for. When should it come on? Thanks, Kerry |
![]() Quote:
One of the reasons the low speed was designed was to reduce fan noise.
Thread Tools | |
Display Modes | |
Air bag Light and code P0480 | db300 | General Turbo Discussions | 2 | 01 Oct 2017 02:22 pm |
'05 throwing P0480 & P0481 after AC job...? | AcIdBuRn02ZTS | General PT Cruiser Discussions | 11 | 22 Jun 2017 08:43 am |
P0480 need help asap | 203turbopt | General Turbo Discussions | 7 | 25 Sep 2012 04:49 pm |
need some help with another error code P0480 on a 2007 pt cruiser | 07ptcruzin | Tech & Performance Forum | 4 | 11 Nov 2008 06:27 pm |
Computer code # P0480 | MINIHEMI46 | General Turbo Discussions | 10 | 17 Jul 2007 04:04 pm |
