Lets' see what we can f*** with next
Like Tree5Likes
  #11 (permalink)
Old 14 Jun 2018, 05:01 pm
ajhockey3's Avatar
Default Re: Lets' see what we can f*** with next
Originally Posted by GotToGo View Post
Went to a different yard today and looked at about 10 cruisers. No visors.
But I did spot some door sills.
The aluminum plates cleaned up nicely but the wings are a bit cruddy.
I have a couple more yards in the area, any other ideas?
The fake carbon fiber dash thing, Parking sensors
2006 PT Cruiser Base 2.4L NA $250
  #12 (permalink)
Old 14 Jun 2018, 05:07 pm
Haha, it already has the carbon fiber dash. I was looking at the cranberry dash parts today.
What are the parking sensors?
03 Turbo AutoStick
107K
Cranny
  #13 (permalink)
Old 14 Jun 2018, 06:09 pm
ajhockey3's Avatar
Its in the mopar catalog, never actually seen them
  #14 (permalink)
Old 14 Jun 2018, 07:26 pm
rckstein's Avatar
Originally Posted by ajhockey3 View Post
So do you have to drill a spot out and run a wire through the rocker panels?
There are enough holes in the outside and inside rocker panels to utilize.
The plates are installed onto the stock covers by drilling a hole for the wire to pass through:
This is one of the slots on the outside of the rocker that the stock sill plates lock into. Then I took a rat tail file to create a clearance notch for the wire:
Then on the inside of the rocker remove the trim panel and remove one of the rubber grommets, and use a rat tail file to create a clearance notch for the wire:
Then using a string feed the wire from the lighted sill plate through both holes with the notches:
Then replace the grommet for the interior trim panel, the notches provide clearance for the wire:
Connect the wires from the sill plates to the wiring from the transformer:
I modified the installation instructions by hiding the transformer behind the trim panel below the seat belt on the drivers side. You only have to tap into the door switch wiring on the drivers side. Then I fed the wire to the passenger side under the carpet behind the front seats. Fed it through from half way from the drivers side then went to the passenger side, reached under the carpet and pulled it through:
'06 Touring Edition NA Automatic
164k Miles / Electric Blue Pearl
USMC '82 - '93
Lets See Your Hub Caps Gracefulspice Wheels, Tires, Suspension 2 07 Sep 2007 12:41 pm
Lets try this again...kit for sale sakigt Classifieds: For Sale/Trade 29 05 Jan 2004 07:58 pm
