This might sound stupid, but when was the last time the transmission fluid/filter was changed? My PT had a rough idle (slight stumble/surge/vibrating and no codes), worst when in gear, even worst when A/C was on, but ran smooth while driving. It's always had a slight rough idle since we purchased new. Would even stumble and stall on a few rare occasions, when going from park to reverse (prompting dealer visits). Took it to the dealer a few times when it stalled, starting around 12K with no success (either plugs, wires or plenum seals changed at each visit), it just got progressively worst to the point it felt/sounded like i was driving an old diesel VW. Well, i replaced the tranny fluid and filter this weekend and it purrs like a kitten. I did not touch anything else under the hood (could have bumped a hose or wire), but after I swapped out the filter, the car has never idled so good! My wife drove it to work for the first time to day and sent me a text saying it felt like a new car. Maybe it was just a fluke or the fluid was just nasty enough to over burden the torque converter? No clue, but i thought I'd share my experience, while you waited on one of the more helpful/knowledgeable folks chime in.
![]() Quote:
![]() 2006 PT Cruiser Base 2.4L NA $250 Last edited by ajhockey3; 18 Jun 2018 at 11:15 am. |
![]() Quote:
However, this could be a bad fuel pump. Almost everything else that would cause this will throw a code or two. ![]()
I would suggest pulling the camshaft sensor plug off and see if the PCM triggers the code for it.
If at First You Don't Succeed - Try, Try Again |
![]() Quote:
![]() 2006 PT Cruiser Base 2.4L NA $250 |
Also, as it is a 2001, check to see if the wire harness has dropped underneath the passenger side of the engine and is rubbing on the half shaft.
2005 Toyota Camry LE Salsa Red (Wife's) 2002 Automatic N/A (Mine) Inferno Red 2016 Kia Soul Plus Black |
when is the last time oxygen sensors were changed
2003 GT M/T in Onyx Green Pearl on Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17. Dark Slate Gray Interior. OEM cargo net, parcel shelf, slush mats and trunk protector, mud flaps, mopar subwoofer. Platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover. Generic lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit. Urethane insert engine mounts. Energy suspension full body urethane bushing kit. Chrysler premium front speakers, Jenson 6x9 rears. Boston Audio 4x55W amp. Panasonic head unit with xtenzi bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter |
![]() Quote:
Soyomb gave some good advice above too. Even though it would likely throw a code, check that the harness is not rubbing the CV shaft.
Thread Tools | |
Display Modes | |
03 gt running rough, stalling | cannesman | General Turbo Discussions | 37 | 10 May 2016 08:03 am |
Running rough, sometimes... | primostoy | General PT Cruiser Discussions | 10 | 16 Jul 2012 03:52 pm |
PT GT running hot and rough AC idle | thefish | General Turbo Discussions | 1 | 10 Jul 2012 07:19 am |
Rough running '06 GT | CruzinGT | General Turbo Discussions | 14 | 21 Nov 2010 08:45 pm |
01 PT Running Rough | lucky594 | Tech & Performance Forum | 5 | 17 Aug 2007 11:22 am |
