Car quit
  • 1 Post By ajhockey3
Old 25 Jun 2018, 06:54 am
Default Car quit
Hi all. Story is; driving along about 30 MPH. Loud bang, engine quit, CEL on, crank sensor code. Engine cranks albeit very slowly with no oomph. Will not start. Fearing it's the timing belt, which I am not able to check. Thanx in advance.
'03 GT Turbo.
Old 25 Jun 2018, 07:41 am
rckstein's Avatar
Default Re: Car quit
How many miles on your PT? Has the timing belt ever been replaced?
There is an inspection hole in the center of the upper cover (in the left cover of the below pic). Remove the plug, crank the engine and you can see if the cam gears are turning.
Old 25 Jun 2018, 07:53 am
You can also check the timing belt by taking off the camshaft sensor and see if the camshaft is turning when you have someone try to start the engine.
Old 25 Jun 2018, 08:41 am
Fk5 Fk5 is offline
Sorry to hear.
Loud bang is almost always bad. Timing belt may be one of your better case scenarios. In my experience, when the timing belt breaks they turn over faster because only the bottom half is spinning. The noise will be different. The old 2.2s were non-interference and we just used to run them until they broke. The couple of times it happened to me, I knew right away.
2003 GT 5 speed
162,000 miles
Old 25 Jun 2018, 05:51 pm
ajhockey3's Avatar
Originally Posted by Fk5 View Post
2.2s
? Don't you mean 2.4
2006 PT Cruiser Base 2.4L NA $250
Old 25 Jun 2018, 09:13 pm
Goonior's Avatar
He means the Chrysler 2.2's of the 80's. They also were belt driven camshafts...
2004 N/A auto. Touring Edition (Died 2016 resurrected Nov 2017) bought for $100 Oct 2017 w/122k mi, died March 2019 143K mi, engine replaced with 2004 w/ 71K in October 2019. Added RBQ 6-disc changer w/Sirius. Replaced TB,WP, thermostat and gasket, front bearings w/one hub, ceramic pads w/new rotors, one brake caliper w/bracket, and lower control arm. More changes/repairs as the weather allows .
1999 300M 196k mi (now her daily driver)
"The most terrifying words in the English language are: I'm from the government and I'm here to help." Ronald Reagan
Old 26 Jun 2018, 08:02 am
Thanx for the reply. Car has 105,000 miles on it. I don't know if the belt has ever been changed. As I stated. I am not physically able to check. Gotta spend more moolah to have it looked at.
Old 26 Jun 2018, 09:40 am
ajhockey3's Avatar
I don't know your physical state, but if you put touch up paint on the two gears in the opening and crank it, if they don't move your timing belt has snapped.
The cover is a PITA to remove but to put a bit of paint on the gears is easy, and doesn't require removal of the cover
oldthom likes this.
Old 26 Jun 2018, 02:03 pm
rckstein's Avatar
All that has to be done is to remove the plug in the inspection hole in the upper cover, the cam gears can be seen through the hole:
(not my PT but a pic from the internet)
Have someone crank the engine while viewing in the inspection hole, if the gears don't turn, then it's most likely the timing belt has snapped.
Radiator Fan Quit gfahr60 PT Cruiser Videos 5 01 Feb 2014 08:24 pm
AC quit sonocativo General PT Cruiser Discussions 10 18 Jul 2012 02:11 pm
Radiator fan quit mheff General PT Cruiser Discussions 9 10 Jul 2012 09:30 pm
Remote Start Quit NightWing General PT Cruiser Discussions 9 19 Mar 2012 11:25 pm
Quit Cruizin 80demoace Tech & Performance Forum 14 22 Jun 2008 04:04 pm
