tailgate issue Im so confused
Like Tree5Likes
  • 1 Post By rckstein
  • 1 Post By scroller
  • 1 Post By waxclan
Old 04 Jul 2018, 10:52 pm
Default tailgate issue Im so confused
My tailgate will only open with the key....until once a year when I go up into the mountains a much higher elevation then I can open it by hand like your supposed to. Why is it when I get back to the lower elevations I have to open it with the key again? any ideas? thanks
Old 05 Jul 2018, 06:47 am
rckstein's Avatar
Default Re: tailgate issue Im so confused
According to your past posts, you have an '07 Limited.
I can't comment on the elevation issue, why the switch starts working sometimes, it just may be a coincidence. Luckily your PT has the lock cylinder on the rear hatch and you can still open it that way. Later PT's the lock cylinder was removed.
Your touchpad switch has most likely failed, or is in the process of completely failing.
There are several threads on this forum on how to install a separate switch taking the place of the touchpad switch, rather than replace the entire outside emblem/latch assembly.
Here is one and you can use the search feature to find others:
Liftgate touchpad replacement
scroller likes this.
Old 05 Jul 2018, 08:10 pm
perfect thank you for your help I truly appreciate it.
rckstein likes this.
Old 05 Jul 2018, 09:12 pm
rckstein's Avatar
This was the switch I installed on my PT when the touchpad switch failed:
This Dorman switch # 84822 is available at auto parts stores:
https://www.dormanproducts.com/p-73336-84822.aspx
It's actually a very easy repair and the type of switch that Chrysler should have used instead of the troublesome touchpad which will eventually fail.
ptprice likes this.
Old 06 Jul 2018, 02:57 pm
ptprice's Avatar
As you get higher up in the mountains the ambient air pressure decreases. This lesser ambient air pressure might allow your hatch latch switch to function, so it probably isn't the RCKEM.
I was getting intermittent function with SOOO BIG's rear hatch latch and just replaced it along with the RCKEM.
That was in Nov. of 2014 and it still functions every time. I'm guessing the replacement rear hatch latch had an upgraded switch. I also replaced the remote control keyless entry module at the same time as portion of the module dedicated to function of the hatch switch was burned out. I learned the hard way, when the switch finally goes it usually goes out in the open position burning out that portion of the module. It seems that your switch has served you so far without burning out the module.
$100.00 plus shipping from a very reasonable Chrysler dealer, Parks Motors, Augusta, Kansas.
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 14 Jul 2018, 07:15 pm
Thank You for your help. I took your advice and am putting a new switch in, I had power to the wires when I started but now I don't have power to that wire. I tested the power to the rear wiper just to see if I had a bad ground but that lit up like it was supposed to. Is there a fuse that might have blown...my manual is of little assistance here.
Thank you
Old 14 Jul 2018, 08:04 pm
rckstein's Avatar
Thank you
The fuse in cavity #10 a 20amp yellow fuse is for the power door locks.
Old 14 Jul 2018, 10:12 pm
thank you
Old 15 Jul 2018, 09:42 am
Thank you
just touch the 2 wires together- what we call bridging the gap... much easier than ringing out for voltage, which may be too low of a signal to show....
Old 08 Aug 2018, 07:36 pm
My 08 pressure pad just went bad. Bought the switch shown and installed in 1 hour. Hatch opening seems to be more positive. Thanx for the pictures.
PT Tailgate tent hotblkpt Classifieds: For Sale/Trade 0 25 Jan 2018 03:09 am
Tailgate thecabinguy General PT Cruiser Discussions 0 13 Oct 2017 05:34 pm
Tailgate mmsam Feedback and Support 3 18 Mar 2016 06:39 am
tailgate abs josephstylist Exterior Accessories Forum 24 18 Apr 2014 09:58 pm
split tailgate rzeigler@cfl.rr.com Exterior Accessories Forum 4 18 Sep 2005 08:34 pm
