Power steering loss
Old 15 Jul 2018, 12:14 pm
Default Power steering loss
Not a good morning. Finally had two rear tires put on the PT, leave the tire place and loose power steering about 6 miles away while turning into Walmarts. Park and fluid leaking out. Made it home about another 8 miles away. Letting it cool so I can get a better look at the situation if I even can.
Searching the issue on here looks like it's just not a simple fix. My question is if I leave it with out fixing will driving the car with no power assist steering be bad for the car? I'm thinking it would be a good workout for the old arms.
Thanks guys / gals !!
Old 15 Jul 2018, 01:49 pm
Macgyverman1123's Avatar
Default Re: Power steering loss
Sorry to hear about your eventful morning!
In regards to your diagnosis, I would top off the reservoir and then start it up. See where the leak is. Keep in mind, it may only leak when the wheel is turned one way or another, so you could have a helper crank the wheel back and forth with the engine going while you grab a flashlight and check for leaks.
Keep in mind, power steering systems also operate at very high pressures, in some cars those little tiny pumps can crank out over 1,600 PSI, so start with the obvious: Check to make sure none of the lines have come disconnected or have any major holes in the, before you resort to replacing the pump/reservoir/rack. Good luck!
Old 15 Jul 2018, 03:56 pm
LionPT's Avatar
I drove mine for about 2 months before I replaced the pump, I havn't had any problems.
Old 15 Jul 2018, 04:15 pm
After blocking up the car and spending a considerable amount of time under there checking the lines I think I need to replace the rack. The leak when I noticed it after the steering gave out was on the right side by wheel. The lines on the rack have a lot of rust on them, especially the right side. Also the boot on the right side of the rack is soaked with fluid.
Any thoughts on replacing the rack? I see them complete on Amazon for about 130.00. The 2 lines going up to the reservoir seem to be in good shape. This car is from up north where the winter road treatments cause havok on autos.
Old 15 Jul 2018, 05:42 pm
ajhockey3's Avatar
I think my grandpa told me its a 1.5-2 hour book time job, thought I had an issue with it at one point and was considering replacing. Depends if your bolts snap off too, Could be a pain
2006 PT Cruiser Base 2.4L NA $250
Old 15 Jul 2018, 06:56 pm
JonN's Avatar
I had my power steering rack replaced last year with the same symptoms as yours.
Was charged $210 for the rack and 2.5 hours labor. A new power steering rack will come with new inner tie rods as well. I decided to to also have my mechanic replace the outer tie rods for peace of mind while everything was apart and got an alignment afterwards.
Between everything I paid $500
2016 Jeep Patriot Sport 2.4L 6 speed auto 97k
NRS brakes and energy suspension bushings
Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 16 Jul 2018, 09:27 am
I paid $40 for mine out of a pull a part yard. Took me just a few minutes to grab it because the engine and trans were gone. Replacing mine took me about 6 frigging hours. A helper would have been handy as well as an overhead rack. I won't ever do another one and won't do one for anyone else. I'd have to charge $1000. The hardest part was getting the drift pin back into the steering link. That and I effed up when I got the steering wheel connection piece stuck up under the firewall and didn't notice it. I kept trying to jack up the rack and the car started lifting. That was my first and last one. If you have the money, just pay someone else to do it. It's a royal pain.
Old 17 Jul 2018, 06:27 pm
Just another question. Would the rack and pinion with a slow leak have caused the engine light to come on? I think this has been going for a few weeks and all of a sudden totally went. I see that there is some kind of sensor on the r & b.
Old 18 Jul 2018, 07:42 am
There's a pressure switch on the drivers side of the rack, but IDK if it would trip a CEL or not. I'm sure someone else will know, though.
Old 18 Jul 2018, 08:58 am
VsandFords's Avatar
The pressure switch on my '01 LE sent a code and the light came on.
Loss of power steering, brakes & rough engine hotinhavasu Tech & Performance Forum 1 30 Nov 2013 01:55 am
Sudden loss of Power Steering after PT being jump started? lanies_ptcruiser02 General PT Cruiser Discussions 16 08 Sep 2010 10:20 am
Power steering Loss driveability Tech & Performance Forum 3 24 Feb 2010 09:31 pm
Power Loss LoboMXGT Turbo Performance 2 15 Aug 2005 04:00 pm
Power loss Betsey General Turbo Discussions 5 10 Dec 2003 03:45 am
