08 PT Cruise with oil residue between upper and lower manifolds???
Like Tree2Likes
Old 25 Jul 2018, 01:05 pm
Default 08 PT Cruise with oil residue between upper and lower manifolds???
What does it mean when I found oil between the upper and lower manifolds??
I'm in the process of changing the thermostat and when I removed the upper manifold, there was oil (and pretty thick in a couple of spots) around the "holes" for the gasses.
Help.
Old 25 Jul 2018, 02:37 pm
Default Re: 08 PT Cruise with oil residue between upper and lower manifolds???
Does your Pt Cruiser have the turbo?
Old 25 Jul 2018, 03:18 pm
No.
Is there / Are there supposed to be gaskets between the two manifold halves?
Old 25 Jul 2018, 03:44 pm
There is the Intake Manifold Gasket Set sold on Rockauto for under $10... but as far as I know... shouldn't only air be traveling through there?
I think there is another issue if you are getting oil residue there. Has the PCV valve been replaced recently? I don't think that has anything to do with it though...
do you have any pictures ?
--2006 pt cruiser non turbo owner. Completely stock... For now.
Old 25 Jul 2018, 11:50 pm
Handy_Cruiser's Avatar
Help.
There's about a 90% chance that this is from engine blow-by. Pull the intake hose off the throttle body and see if it's really oily. If so, you have your answer. Make sure the PVC hose is not kinked. Changing the PCV valve may help. But it may not. Adding an external PCV vent may help too.
Old 26 Jul 2018, 04:27 am
I noticed an oily slime on the intake runners of my 2006 NA PT. [It burns/leaks a quart of oil per oil change]. I changed the PCV valve with a factory valve. Washed and lightly oiled the little foam filter in the air box. Checked the hose.
I think this is normal. It's just the hot oil fumes condensing on the cool intake manifold. [theory]
There are formed 'O ring' gaskets between the intake manifold halves.
dougs likes this.
Old 26 Jul 2018, 08:05 am
Goonior's Avatar
I noticed this the other day when I regapped my plugs. Was going to post the same question...
2004 N/A auto. Touring Edition (Died 2016 resurrected Nov 2017) bought for $100 Oct 2017 w/122k mi, died March 2019 143K mi, engine replaced with 2004 w/ 71K in October 2019. Added RBQ 6-disc changer w/Sirius. Replaced TB,WP, thermostat and gasket, front bearings w/one hub, ceramic pads w/new rotors, one brake caliper w/bracket, and lower control arm. More changes/repairs as the weather allows .
1999 300M 196k mi (now her daily driver)
"The most terrifying words in the English language are: I'm from the government and I'm here to help." Ronald Reagan
Old 27 Jul 2018, 12:49 pm
Changed the plugs on my 08 PT 77K mi today and noticed the same thing. It uses about 1 to 1 1/2 qt between 3000 mi oil change interval. Nothing seemed wrong with the PCV valve but changed it anyway. Observed no oil in the air box or on the small filter. IIRC, there has always been an oily film inside the intake runners every time it has been disassembled. Maybe just the PCV valve doing its job.
Old 27 Jul 2018, 03:15 pm
UPDATE:
I have it all back together, now I'm getting a new code I've never seen before:
P1684 "Drive 5 Line 4"
still getting P0304 like always.
Old 30 Jul 2018, 10:24 am
Started and ran with ac on high for 10 minutes
Fan doesn't work.
Also, idles real low - to the point of stalling if I leave it in drive.
Just heard a new noise - happy happy - seemed to go away when I turned off the ac. Sort of a but not quite a grinding noise but very intermittent.
Upper an lower intake manifolds muzicmax Turbo Performance 4 31 Jul 2013 11:25 am
FS Upper and lower composite intake fabreezai Classifieds: For Sale/Trade 3 29 Apr 2012 05:06 pm
Upper, Lower, Cold, Hot??? Busa_Powered General PT Cruiser Discussions 5 04 Nov 2011 03:27 pm
06 turbo upper/lower intake muzicmax Turbo Performance 4 19 May 2011 05:41 pm
WTB Hot Rod Grill Upper and Lower IRPT Vendors & Buyers Forum 1 14 Nov 2003 01:36 am
