minor tiny dimming lights
Old 27 Jul 2018, 02:08 pm
Default minor tiny dimming lights
I have noticed while driving home at night on the highway, all the lights in my PT slightly dim. You almost don't notice it, but I can just barely make out that the lights flicker just slightly. This is not a completely shutoff and turn on, it just dims slightly then comes back.
I noticed it on my 04 and now on my DC2, Just a slight tiny bit of a dim, then comes back, then barely dims. It doesnt happen all the time, usually after the car warms up, but I have seen it before it does get cold. I know it's not any load on the system, as my radio is usually off, and I have replaced all but the headlights with LEDs, so I shouldn't be putting too much of a load.
Wondering if anyone else has noticed this, and if they know of any fixes. I'm thinking either a weak battery/alternator? I'm not sure, but It acts like how lights dim slightly when bass hits in a high end audio system, but again, my radio is off. So i'm not sure. I think installing a large capacitor would fix the issue, as i know its a drop i voltage, but I'd rather fix the root cause.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 27 Jul 2018, 02:34 pm
rcktpwrd's Avatar
Cool Re: minor tiny dimming lights
check all of the grounds...
Joel
www.rcktpwrd.com
Old 27 Jul 2018, 06:22 pm
Default Re: minor tiny dimming lights
It could be the voltage regulator which is in the PCM. It is not in the alternator.
The alternator could be putting out too little power.
The battery may be bad
The multi function switch may have the dimmer set low - slide it back up.
- You said this happens on the freeway. Is it only while cruising at a high speed where the lights start to dim? If so, I would think it is the alternator or the voltage regulator in the pcm (not sure how it works, I've never heard of the voltage regulator going bad) I am thinking the alternator is not providing enough power. (wild guess - I have never experienced this issue)
--2006 pt cruiser non turbo owner. Completely stock... For now.
Old 28 Jul 2018, 02:56 am
2006 NA -- After driving for 5 minutes at night I come to a stop sign. The headlights will dim slightly and return to 'normal'. Very slight change, as if the charging voltage went from 14v to 13.5v to 14v. for a split second. It's been doing this for years, I'm not concerned. ----- The hi-speed radiator fan is a high current device. Another possibility for intermittent current draw.
Old 28 Jul 2018, 07:55 am
Is the alternator belt tight?
Old 28 Jul 2018, 09:49 am
rckstein's Avatar
Mine used to do that, too, until I replaced the TIPM and it hasn't done it since.
Old 29 Jul 2018, 02:16 am
_PTGT03's Avatar
I had this same problem.
I just installed a resistor in series with the battery temperature sensor, this determines what voltage and current output the alternator delivers to the electrical system. Over time the battery temp sensor breaks down and give inaccurate information to the PCM. Now, the voltage is always at least 14 to 14.4 volts
Old 29 Jul 2018, 08:43 am
rckstein's Avatar
The Gen2 doesn't have the battery temp sensor, like the Gen1 does.
Old 30 Jul 2018, 07:17 am
Isn't he talking about his 03 Dream Crusier, Rick? Now I'm confused.
Old 30 Jul 2018, 07:50 am
rckstein's Avatar
I was commenting about the post from pt06, he has a Gen2 the same year as mine and his had the same "quirk" as mine.
Lights dimming! insanepagen Sound and Security Forum 2 28 Nov 2011 06:37 pm
Dimming lights 05Cruizer Sound and Security Forum 1 31 Mar 2010 01:15 pm
Lights are still dimming justine311 Tech & Performance Forum 4 19 Apr 2006 01:47 pm
lights dimming hawkeye_1 General Turbo Discussions 11 22 Nov 2004 02:09 pm
DIMMING LIGHTS AND PCM'S 1SPRINKLERMAN General PT Cruiser Discussions 9 26 Jan 2004 10:04 pm
