Weird problem with my turn signals.
Like Tree13Likes
Old 02 Aug 2018, 05:08 pm
Default Weird problem with my turn signals.
Alright, this started a few weeks ago.
The turn signals barely click, or click for a few times then shut off. Then later (during the same drive) they work like they should.
I don't think the bulbs are bad, otherwise they would click rapidly. I also changed the fuses that pertain to the left and right signals. Not sure what's going on here.
I have a 40 second vid that i took. But i can't to upload to imgur, and attaching it with the thread options doesn't seem to work.
Old 02 Aug 2018, 07:04 pm
Default Re: Weird problem with my turn signals.
Are all four bulbs doing the same problem?
Is there any difference whether it is the left side or the right side that is blicking?
Old 02 Aug 2018, 08:01 pm
Yeah, seems like it.
I flip the left, and it will blink a few times then stop. Then i switch to the right and the same... Then after a while they will work fine.
I really wish i could post the video
Old 02 Aug 2018, 08:09 pm
For the moderators, this is the message i get when i try to upload the vid.
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
Old 02 Aug 2018, 08:39 pm
rckstein's Avatar
There currently is no forum moderator.
Post your video to YouTube and then you can post the video in a thread post.
Old 02 Aug 2018, 09:53 pm
Ok, I'm gonna do that.
Gimme a few
Old 02 Aug 2018, 09:58 pm
Ok, here's the link. I don't know how to embed the video on this forum.
If someone can give me the embed code. I'll fix it
https://youtu.be/4Nrhs3aBBM8
Old 02 Aug 2018, 10:08 pm
Does the hazard lights also stops blinking?
Old 02 Aug 2018, 10:11 pm
Haven't tried that.
Old 02 Aug 2018, 10:39 pm
rckstein's Avatar
Your vehicle is running and the Check Engine Light is on.
Do you have any codes related to that?
Doesn't the Gen1 have a separate, replaceable, turn signal/hazard flasher, where the Gen2 it's built into the instrument cluster?
I found this online:
"The turn signal flasher and the hazard warning flasher are combined into one unit called a Combination Flasher (combo-flasher) The combo-flasher is a smart relay located on the back of the multi-function switch (Turn Signal ). The combo-flasher is black in color and has a dampener material wrapped on it. The flasher is mounted to the back side of the multi-function switch Combination-Flasher The flasher is serviced separately from the multi-function switch."
Here's your vid:
Turn signals CREWZIN Tech & Performance Forum 8 02 Mar 2015 05:09 pm
no turn signals Darkchylde Tech & Performance Forum 13 29 Mar 2014 10:44 am
turn signals yukonak2 General PT Cruiser Discussions 7 10 Sep 2013 01:44 pm
2007 problem solved - No turn signals, no wipers, no highbeams, lights on Nameless1 Tech & Performance Forum 7 15 Aug 2013 07:36 pm
turn signals AlexJB Exterior Accessories Forum 6 12 May 2008 08:12 pm
