PT Cruiser Air conditioner issue
  • 1 Post By Sinbad
Old 05 Aug 2018, 10:40 pm
Tucker05's Avatar
Default PT Cruiser Air conditioner issue
Ok so I have a 2005 GT. Replaced the air conditioner lines. Charged the system and it only worked for the one day. Then nothing the next day. Checked and there is still freon in the system. I am at a loss for what I should do next.
Old 05 Aug 2018, 11:52 pm
Default Re: PT Cruiser Air conditioner issue
Is there enough pressure to keep the low pressure switch closed?
Is the high speed fan running to cool freon?
did one of the wiring connectors come loose?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 06 Aug 2018, 12:37 am
Sinbad's Avatar
Did you replace the drier receiver at the same time?
If you didn't, you now need to to eliminate it from causing your problem - and from potentially wrecking your compressor.
Rule of thumb:
if you are going to open the AC system - ALWAYS budget for a new D/R.
They are peanuts - half the cost getting it de-gassed and re-gassed - which you'll have to now...
_________________________________________
'07 2.2 CRD
Old 06 Aug 2018, 01:14 am
Rule of thumb:
This thread below after reading it completely is very helpful.
http://www.ptcruiserlinks.com/forum/...tem-print.html
Old 06 Aug 2018, 06:47 am
Tucker05's Avatar
I did change the dryer as well. I have to check the levels. I guess the D.I.Y recharge did not have enough. I will have to check it out again. Thanks everyone
Old 06 Aug 2018, 08:34 am
There's a fuse/relay box on the back of the engine. I had a very similar problem. And it ended up being the AC relay/fuse.
air conditioner blows cold but velocity diminishes 06 PT cruiser fijiiw Tech & Performance Forum 3 23 Sep 2013 02:50 pm
Air Conditioner Help chefbunnyk Tech & Performance Forum 6 14 Aug 2013 04:46 pm
Air Conditioner / bad fan issue geohunt Interior Accessories Forum 6 25 Aug 2012 03:36 pm
08 Air Conditioner Issue Sarasmiles Tech & Performance Forum 14 24 Aug 2012 08:34 pm
Air Conditioner Air Conditioner Vaccuum or Flap seal issue??? RMThompson General PT Cruiser Discussions 7 25 Feb 2012 02:40 pm
