PT Cruiser not charging
  • 1 Post By the3dgm
Old 04 Sep 2018, 11:52 am
ajhockey3's Avatar
Default PT Cruiser not charging
PT Cruiser wasn't charging correctly, I put a new alternator and it isn't any better. What Can I check. im so done with this car
2006 PT Cruiser Base 2.4L NA $250
Old 04 Sep 2018, 02:20 pm
rckstein's Avatar
Default Re: PT Cruiser not charging
I don't know what's available in Canada, but in the US, you can take your vehicle by almost any auto parts store (O'Reilly, Auto Zone, Advance Auto, Pep Boys, etc) and they can check the entire starting, charging and battery from the vehicle. You might check at any of your local parts stores to see if they offer that service.
Old 04 Sep 2018, 03:52 pm
Why don't you tell us what led you to replacing the alternator? It may just be a wiring problem in the harness somewhere.
Old 04 Sep 2018, 05:00 pm
ajhockey3's Avatar
The battery light is on, needs a boost after being shut off. Battery voltage while running is 12.5 ish where it should be 13.5+
Old 04 Sep 2018, 05:14 pm
ajhockey3's Avatar
Could someone tell me what the fuseable link looks like?
Old 04 Sep 2018, 06:00 pm
ajhockey3's Avatar
I found the green fuseable link, how can I test it?
Old 04 Sep 2018, 06:09 pm
The same way you would test a fuse, are you getting power to both sides of the link? A fusible link is usually nothing but a smaller gauge wire than is being used so it will melt if hit with an excessive amount of power. JFYI
LionPT likes this.
Old 04 Sep 2018, 08:20 pm
ajhockey3's Avatar
I think its ok, I don't know what else to check, Might just have to get it towed to a garage
Old 04 Sep 2018, 08:49 pm
I would suggest checking every wire from the generator (alternator). Check the group of ground wires going to the drivers side fender. Some members have found broken wires going from the generator to the PCM.
2003 PT Cruiser GT battery not charging Jdhaulr1 General Turbo Discussions 8 29 Mar 2018 04:32 pm
2006 PT cruiser charging problem pappynoodle Tech & Performance Forum 1 05 Nov 2015 04:22 pm
Pt cruiser misfire and charging questions fordtech20 General PT Cruiser Discussions 8 13 Oct 2015 09:23 pm
2001 PT Cruiser - Charging System Problem tdf Tech & Performance Forum 3 21 Jan 2014 05:27 am
charging problems with 01 pt cruiser gdxxman General PT Cruiser Discussions 3 11 May 2009 04:59 am
