A/C Belt Squeak
Like Tree3Likes
  • 1 Post By chuzz
  • 1 Post By rsrocket1
  • 1 Post By rob302
Old 16 Sep 2018, 09:51 pm
Macgyverman1123's Avatar
Default A/C Belt Squeak
Evening!
I have been experiencing a strange issue with my A/C, whenever I have the A/C on and I'm driving in the rain, I hear a belt squeak whenever the compressor cycles on. It squeals like the belt is wet for 2-3 seconds, then goes away. The current A/C belt is only about a year old. The A/C is working normally, no issues at all save for the noise.
Ideas? Should I try replacing the belt again? Is it possible I have a splash shield missing or something?
Old 17 Sep 2018, 06:52 am
Default Re: A/C Belt Squeak
First thing I'd do is check the tension on it. Then look for a missing splash shield. It should be fairly obvious if one's missing.
rsrocket1 likes this.
Old 17 Sep 2018, 07:46 am
rcktpwrd's Avatar
Cool Re: A/C Belt Squeak
has the tensioner ever been replaced?
It could be a bad belt too even thought it's not that old...
also check that the alternator belt is tight, that one is a manual adjustment.
Joel
www.rcktpwrd.com
Old 17 Sep 2018, 08:18 am
Fk5 Fk5 is offline
Mine has been squealing for years. Finally changed it and it stopped for an afternoon and squeaks again. I am missing the splash shield.
2003 GT 5 speed
162,000 miles
Old 17 Sep 2018, 10:09 am
rsrocket1's Avatar
The tensioner is spring loaded and "automatic" (no adjustments). My bet is on the splash shield. You can also get water up there if too many fasteners are missing from one of the splash shields and it acts like an air scoop.
When the tensioner pulley goes bad, it sounds like a constant chirp that follows the engine RPM. Fortunately, it's very easy to replace.
Carl48 likes this.
Old 17 Sep 2018, 10:13 am
rob302's Avatar
squeals for 2-3 seconds when the AC is on and it's raining? i'd fix that by turning the radio up. seriously.
chuzz likes this.
Squeak YumaSal General PT Cruiser Discussions 2 08 Nov 2012 01:23 pm
Squeak paperdoll Tech & Performance Forum 4 29 Jan 2012 06:06 am
Pulley/Belt squeak StealthyK Tech & Performance Forum 3 15 Jul 2011 09:48 pm
squeak coming from eng or belt or pulley? golf55555 General PT Cruiser Discussions 16 03 May 2011 02:44 pm
weird squeak ??? legion General PT Cruiser Discussions 4 07 May 2005 01:42 pm
