all lights flashing on cluster - No power loss
Old 18 Sep 2018, 01:18 pm
Default all lights flashing on cluster - No power loss
I had this issue two years ago or probably longer and it went away. I kept fiddling around with the wiring that goes to the multi-function switch.
Back then, power would also cut off while driving. Very dangerous. Power would cut off for a second or two then come back on.
Issue came back and would love to hear a 100% for sure fix for this.
From what I've read it could be
Bad ground wires around the battery
bad multi-function switch
ignition switch (can't be taken apart in my 2006)
wiring to the multi-function switch
TIPM?
--2006 pt cruiser non turbo owner. Completely stock... For now.
Old 18 Sep 2018, 07:30 pm
Default Re: all lights flashing on cluster - No power loss
Can you post a video of what is flashing?
Old 19 Sep 2018, 07:36 am
I don't have a permanent fix, but sometimes lowering or raising the steering column helps. Wires get pinched in there.
Old 19 Sep 2018, 05:14 pm
No video, but it is ALL dashboard lights, dome light stays off. Imagine turning the key one click and all lights go on. Check engine, abs, oil, everything.
While driving, everything turns off for a millisecond, the lights all turn on, and power is resumed. All this over a fraction of a second.
In the video below, can those wires be completely removed, cleaned off, and re-inserted? I have a feeling my issue is from the connection point below.
Old 19 Sep 2018, 05:23 pm
Can only the ignition switch be replaced without replacing the lock cylinder?
Mine is the 2006 and its the weird version where it doesn't have the hole where you can push in to release the cylinder.
I took it apart but could never get to the inside.
I wish there was a pt cruiser mechanic in southern california.
I may end up taking a road trip to NCAL just to get this fixed by a pro.
Old 19 Sep 2018, 05:27 pm
Old 19 Sep 2018, 09:38 pm
I would suggest doing a battery load test. Sometimes the battery goes bad and the battery voltage goes down just enough to trigger electrical gremlins.
Also suggest checking the ground wires going to both fenders.
This member fixed the problem with a new battery and cleaning the battery cable contacts.
Intermittent issue, wonder if anyone else has this
Old 20 Sep 2018, 02:11 pm
I found lots of similar issues on the web after experiencing these symptoms and R2 the battery was the common fix. R2 my battery and had no issues since. It's been just over 3 years. I know its been 3 years because my battery recently wouldn't hold a charge and it was a month out of its 3 yr warranty Like Steve recommended, have the battery load tested.
Old 20 Sep 2018, 02:32 pm
Fk5 Fk5 is offline
I had a similar problem around Christmas of 2011. The lights would all come on. Dash would go crazy, all numbers flashing, getting super bright. A few weeks prior, I was working a bunch of hours and had a shop do some work on the car. Turned out they took the battery out and didn't tighten it back up. The terminals were tight, so when I checked it seemed fine. I tightened it at the toll booth for the Whitestone Bridge, 4:00 am 16 December. All good ever since.
2003 GT 5 speed
162,000 miles
Old 22 Sep 2018, 11:03 pm
What is R2 the battery?
Ground to battery? I do have corrosion on the attachments and the battery is about 2 years old.. battery should be decent.
I'll tell mechanic to replace all ground wires? Isn't it known as the big 3? Should I go to a mechanic or an audio shop?
Gauge cluster lights, shifter lights, and rear running lights out Jspata Tech & Performance Forum 3 18 Oct 2016 04:33 am
Start-up Issues plus all lights flashing and loss of power while driving. funkyfred General PT Cruiser Discussions 3 15 Mar 2016 07:59 pm
Flashing red light in black dot within instrument cluster CruiserLady Interior Accessories Forum 4 10 Nov 2012 10:43 pm
Flashing dash lights mystynm General PT Cruiser Discussions 4 04 Apr 2012 05:29 pm
Help! Flashing dashboard lights! Silvercat Tech & Performance Forum 2 31 Jan 2011 11:24 am
