Idling High? Too much noise....
Old 16 Jul 2004, 10:07 pm
Default Idling High? Too much noise....
I'm a new PT owner, and can't believe I found this site. Help me out here before I have to spend a day at the dealer for something that may be normal. I have an 02 Touring Edition that seems to idle to loud, or to high, or something. It drives great, doesn't seem to have any other problems, just seems a little too loud, especially if you are standing outside of it. I bought it used; it was the first one I actually drove, fell if love with it, and the price and mileage were great, so bought it. Now I'm wondering if there is something wrong with it because of the noise. Anyone else have this, or is it just normal? [:I]
Old 16 Jul 2004, 10:27 pm
Send a message via AIM to Konkeler
lol, a 4-Banger idling loud!!! Thats a first. If you can still hear each-other talk using a normal volume of voice that it ain't loud enough!!! [8D]
Ok ok, seriously though, does it always seem to be loud or just when it idles. Might be a hole in the exhaust. What RPMs is it at when it idles??
Here is picture of My Cruiser\'s Mirror
Old 16 Jul 2004, 10:41 pm
Just seeem loud when idling, not when driving it. It's idling right at about 1 RPM, maybe just a bit more now and then.
Old 16 Jul 2004, 10:52 pm
That is a little high. Does it change when the AC is turned on? The idle should be about 750 rpm. It is controlled by the Idle Air Control Motor which receives it's signal from the PCM. There should be codes thrown if the sensors to the PCM are out of whack.
Old 16 Jul 2004, 11:00 pm
Not sure if it's changing with AC on, just haven't listened both ways yet. Will pay attention to it in the morning when I go out. Sounds like I should go ahead and take it in if it's idling higher thatn it should. I try it with and without AC tomorrow. Thanks!
Old 17 Jul 2004, 09:47 am
All three of my PTs idled around 1000RPM. Sounds fairly normal to me. Is your PT an auto, they tend to idle a little higher. [:I]
P.S. Welcome to the board, and to cruising. [?]
03 DC2 Turbo GT 5 Speed(Hers)
03 Electric Blue TE Auto (mine)
Old 17 Jul 2004, 12:59 pm
Are you listening to your idle when its cold in the morning?
Old 17 Jul 2004, 01:55 pm
When the car is cold, it will idle somewhat faster. This is normal. Can't speak for NA PT's since mine is a GT but once warm, mine never idles above 800 rpm, with or without the air conditioner.
Even when idling cold, the engine does not sound "loud" nor does it seem like it is idling excessive fast. If you are coming from a big block V-8, it certainly does have a different sound. I certainly doesn't have the slow lope of a big block with a cam.
Old 17 Jul 2004, 03:47 pm
white's Avatar
I had a 01 LE that was loud but my new 04 GT is very quiet. I even had the 01 into the dealer and of course they said it was normal.
E. White
2010 Black over Silver, Couture Edition
Old 17 Jul 2004, 10:40 pm
My PT will idle at 1,000 on a cold mornming until Temp is up, then never above 800 (more like 750). In summer, a little higher than 800 is A/C is on.
Since it's used, I wondered if it had an intake, but then it wouldn't just be noisy at idle.
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
acceleration and decceleration popping noise Art Rigby Tech & Performance Forum 1 06 Oct 2003 02:30 pm
