Back firing
Like Tree2Likes
Old 06 Oct 2018, 09:31 am
loomex's Avatar
Default Back firing
My poor little Christine is backfiring when I downshift. There no issues with acceleration. I can mash the pedal and it goes. The backfiring seems to happen when I downshift or use the engine for braking as in going down hills. The plugs (gapped at .04) and wires were replaced last summer, the cam sensor was replaced last summer and the timing belt was replaced in February. I have no codes and the car runs fine. It's an 02 NA 5sp.
"Christine", a 2002 (manufacture date 8/2001) base model, 2.4L 5-speed.
USAF 83-92, IRR 92-94, NV ANG 94-98, IRR 98-00
Old 06 Oct 2018, 10:33 am
Default Re: Back firing
How are you checking for codes?
Do you have an exhaust leak?
Does it backfire if you don't use the brake when going downhill? I would check the vacuum line going to the brake booster.
Old 06 Oct 2018, 12:09 pm
loomex's Avatar
No codes are showing up
I will have to crawl under and check for leaks, but I don't believe I have any
The next time I drive it, I will listen for any change while braking
Old 06 Oct 2018, 01:04 pm
I would suggest hooking up a vacuum gauge to see what the needle does if you have one.
A vacuum gauge is not the proper direction for troubleshooting a backfire it might tell us if the timing is okay. Checking the fuel pressure, and exhaust restrictions might help us but we can do any diagnostics that we can without gauges first.
How is the acceleration?
Old 06 Oct 2018, 04:01 pm
_PTGT03's Avatar
you must be having a hole in your catalytic converter. once the cat is removed or has a hole you can hear pops when you decelerate. the cat helps to muffle a lot of the sound. that's my theory anyway. i run a straight Y-pipe with syked tune engine management software, it's designed to pop very loudly when decelerating. i like the noise although.,
Old 06 Oct 2018, 06:39 pm
loomex's Avatar
ptcruisersteve,
My acceleration is great with no issues. I have a vacuum gage, but would not know where to hook it up for testing
_PTGT03,
Removing the catalytic converter is a big no-no in NYS
Old 06 Oct 2018, 07:12 pm
JonN's Avatar
I've connected a gauge to a vacuum port at the throttle body area. My 2.4 NA PT typically does around 17.5 InHg at idle.
BIG RED '01 LE 193K and counting!
Vision Cross 16x7 Rims, 205/55/16 , Painted Calipers, Spoiler, CAI, Pioneer DEH-64BT head unit, NEW Skar SKv2 200.4 amplifier 2 RF P2D2 12's, RF P1T-S Tweets, RF PPS4-6 Mids, RF 6x8"s, AudioControl 24XS crossover/line driver
Newest Car
2016 Jeep Patriot Sport 2.4L 6 speed auto 92k
NRS brakes and energy suspension bushings
Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 06 Oct 2018, 07:46 pm
Originally Posted by loomex View Post
ptcruisersteve,
_PTGT03,
When you do get the vacuum gauge hooked up see what happens when you decelerate quickly. See if it matches post #4 on quick deceleration.
Old 07 Oct 2018, 02:41 pm
loomex's Avatar
Where, exactly do I hook up the gage?
Old 07 Oct 2018, 05:02 pm
You can connect a hand vacuum gauge to the intake manifold either tee into the PCV or the brake hose. Than start your engine and report what the gauge is doing.
loomex likes this.
Cylinder 1 & 3 not firing aka PCM question jollyjeepers Tech & Performance Forum 9 08 Sep 2017 12:40 pm
04 not firing on 1 and 4 ccoffey3131 Tech & Performance Forum 7 29 May 2014 11:36 am
Not Firing Koseck Tech & Performance Forum 3 20 May 2013 02:45 am
Please help again - Sputtering and Back firing clickhere4dawn Tech & Performance Forum 10 23 Nov 2012 11:25 am
2002 PT Cruiser not firing fletch65 Tech & Performance Forum 28 20 Apr 2011 09:46 am
