2001 Trac Off Light Intermittent
Old 08 Oct 2018, 03:33 pm
Default 2001 Trac Off Light Intermittent
The Trac Off light has been coming on intermittently. (No, the Trac Off button is not being pushed).
Any ideas where to search for this?
Driving along everything normal, and then "BING" sounds, the light is on, and then is just goes off again.
Thanks!
Old 08 Oct 2018, 04:44 pm
Default Re: 2001 Trac Off Light Intermittent
Thanks!
I would suggest checking for codes with a scanner that includes ABS codes.
Sometimes one of the wheel sensors starts to go bad and you have the intermit trac light come on.
Old 08 Oct 2018, 06:59 pm
JonN's Avatar
When I had this issue my ABS tone ring was cracked.
BIG RED '01 LE 190K and counting!
Vision Cross 16x7 Rims, 205/55/16 , Painted Calipers, Spoiler, CAI, Pioneer DEH-64BT head unit, NEW Skar SKv2 200.4 amplifier 2 RF P2D2 12's, RF P1T-S Tweets, RF PPS4-6 Mids, RF 6x8"s, AudioControl 24XS crossover/line driver
Newest Car
2016 Jeep Patriot Sport 2.4L 6 speed auto 86k
Powerstop Z23 evolution front brakes, Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 10 Oct 2018, 03:15 pm
I found that the lead to the starter was loose. I tightened it down and haven't seen it since...
Not sure how that could cause this... but maybe?
Old 15 Oct 2018, 07:53 am
mnahmnah's Avatar
I have a 2001 with the Trac light on the dash almost all the time. I've been ignoring it for 10 years and I've seen it go out only once. Does my traction system work? I dunno. :shrug: There have always been more important concerns with mine! May you have better luck!
2001 LE, 168,000 miles.
One of the split seats went into a dumpster in Tulsa. The arm rest unscrewed and fell off. It's on its 2nd timing belt. Surviving the Upper Peninsula winters.
ABS, TRAC, and Brake Dash Light (No ABS or Trac on car) Stretch Tech & Performance Forum 3 16 Nov 2017 05:20 pm
2001 PT Cruiser. limited atx TRAC OFF light domsob1974 Tech & Performance Forum 0 05 Sep 2014 01:24 pm
What does the TRAC light mean? Whistler Tech & Performance Forum 8 23 Feb 2014 12:35 pm
abs/trac warning light rustyred Turbo Wheels/Suspension/Handling 2 30 Jan 2011 04:47 pm
abs trac light donny General PT Cruiser Discussions 1 01 Jun 2010 08:33 am
