horrible heat output
Like Tree3Likes
Old 24 Oct 2018, 10:51 am
Default horrible heat output
ive got a 2003 pt 4 door. the heater output is lukewarm at best. i feel hot heater hoses are hot coming in and out. car came from new york. could the heater core have a bunch of leaves twigs ect blocking airflow or should i try reverse flushing it as it maybe plugged. im kinda stumped on this one. i do hear flapper door opening
Old 24 Oct 2018, 11:07 am
JonN's Avatar
Default Re: horrible heat output
My Dad had this problem with his old '99 Silverado at one point. We took the heater hoses off and reverse flushed by rushing water from the garden hose through it. So much crud came out it wasn't even funny.
After that, we flushed all the coolant out and swapped it for fresh stuff. Heat was fine after that.
BIG RED '01 LE 193K and counting!
Vision Cross 16x7 Rims, 205/55/16 , Painted Calipers, Spoiler, CAI, Pioneer DEH-64BT head unit, NEW Skar SKv2 200.4 amplifier 2 RF P2D2 12's, RF P1T-S Tweets, RF PPS4-6 Mids, RF 6x8"s, AudioControl 24XS crossover/line driver
Newest Car
2016 Jeep Patriot Sport 2.4L 6 speed auto 91k
Powerstop Z23 evolution front brakes, Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 24 Oct 2018, 11:30 am
After you flush the heater core, careful the lines on the core are fragile, check to make sure the radiator is getting hot, could be thermostat or and cap.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 24 Oct 2018, 03:40 pm
Macgyverman1123's Avatar
I would also recommend a reverse and forward flush, followed by a fresh round of HOAT. As others have said, be *extremely* careful with the lines and don't use high pressure water. These cars are known for having delicate heater cores.
After that, I'd recommend making sure you don't have any stuff on the core itself, check for leaves and debris like that. Make sure your engine is actually getting to the proper temperature.
Also, stupid as it sounds, make sure your coolant is full in the radiator and to the proper level in the puke tank. The heater core is one of the highest points in the cooling system, so if you're low on coolant, the heat might not work, but the car may not overheat either.
Good luck!
podo2000 likes this.
Old 24 Oct 2018, 09:55 pm
First things first, check the coolant level and make sure it's full.
Old 01 Nov 2018, 10:32 pm
coolant level is good.
im gonna do the reverse flush soon. which is inlet and which is outlet on the heater core
thank you
Old 02 Nov 2018, 08:28 am
Inlet hose should be the one on top of the engine. Outlet runs to water pump.
Old 11 Nov 2018, 10:51 am
looks like im doing an heater core hose replacement as the hose has a rub mark from rubbing on the fuse box. ill flush it then. its been one problem after another. i just found out the gas tank straps are rotted to nothing and the charcoal canister bracket is non existant. ill add that to the broken sunroof and non working ac andbrake problems. thank goodness i can fix stuff
Old 11 Nov 2018, 11:03 am
rckstein's Avatar
You know the old saying
Old 12 Nov 2018, 08:33 am
You'll need to set aside an entire day for a heater core replacement. It's not a job for the feint of heart. Takes about 8 hours. Dash has to come out.
Weak heat output fordtech20 General PT Cruiser Discussions 12 29 Nov 2015 05:15 pm
New Guy with horrible problem!!!! FJBLTD Welcome New PT Cruiser Members 9 04 Sep 2015 10:50 am
Getting some horrible gas mileage... help? CruseadorPT Tech & Performance Forum 34 01 Sep 2009 12:01 am
Horrible gas mileage maxxheadroom Tech & Performance Forum 3 21 May 2007 08:51 am
