Trouble with LED Headlights?
  • 1 Post By rckstein
Old 29 Oct 2018, 03:57 pm
Default Trouble with LED Headlights?
After doing quite a review search, I ordered the G20-COB-9006 Headlights. It took about a week to get, and we still have some warm days left so I installed them only to find a problem. The symptoms are.... when the car is not running, the LED lights go on with the interior switch, and all is fine. When I start the car, the LED lights flash (by them self's) 3 times then go out! I reversed the sockets thinking they might be in backwards, and the LED lights do not go on at all. I Took out the LEDs and reinstalled by old 9006s, and everything works fine. Before I return these LEDs, is there anything else I can do?
Thanks
Old 29 Oct 2018, 04:45 pm
rckstein's Avatar
Default Re: Trouble with LED Headlights?
Thanks
You have an '07 with the CANbus system. You will have to do some research if you can make the LED headlights work but on some vehicles with a CANbus system, the LED lights don't pull enough of a load and therefore won't work properly without installing an additional load resistor.
This is a sample of what one looks like:
I have LED brake lights and those work with no problem. But when I switched to the Sweeplites for the turn signals, I had to install the load resistors on that circuit for them to work properly because they weren't pulling enough of a load and it would make the front turn signals fault out (rapid flash) as if one of the other bulbs was burned out.
Installed the resistors and no problems.
rockandroller likes this.
Trouble with trouble lights! Harper57 General Turbo Discussions 4 23 Jul 2017 07:57 pm
HID Headlights/Projector Headlights Vengence General PT Cruiser Discussions 4 02 Jan 2017 02:33 pm
A/C trouble mohavemike Tech & Performance Forum 7 14 May 2012 11:08 pm
PT Trouble hotcarl Tech & Performance Forum 6 16 Jul 2007 02:21 pm
PCM trouble too ptgtjoe General Turbo Discussions 6 26 Dec 2003 11:38 am
