Having issues with my left signal light both don't work
  • 1 Post By ptcruisersteve
Old 01 Nov 2018, 12:25 am
Unhappy Having issues with my left signal light both don't work
Hi,
I have an issue with my left signal light replaced bulbs checked no power to the front and back signal. I was searching for a flasher relay Pt Cruiser 2006 does not have a flasher relay. I took the dashboard apart and could not find it. I am pretty sure the relay for the flasher is integrated into the TIPM. I am debating if I should replace the TIPM I found several used one online for under $100. Please I need the forums help.
Old 01 Nov 2018, 11:32 am
Default Re: Having issues with my left signal light both don't work
Does the hazard lights work on both sides?
bob2006 likes this.
Old 14 Nov 2018, 10:40 pm
dougs's Avatar
Two days ago left rear turn signal light stopped working on the 2006. Put in a new bulb, checked the Multi-function switch -- these were ok. Turned out to be a bad pin from the dash data harness into the control module.
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
Tags
flasher, signal, tipm
Left Rear Signal Light Not Working 2006 Model Murphyisbroken General PT Cruiser Discussions 5 19 Apr 2017 11:47 am
Left brake light won't work when pressing down brake pedal ReeseBear Tech & Performance Forum 9 16 Dec 2016 01:39 pm
06 left rear signal will not work. MNTEGRA01 Tech & Performance Forum 18 23 Mar 2015 11:06 am
signal light doesn't work when breaks applied SinglerStudios Tech & Performance Forum 6 24 Jul 2014 07:01 pm
2006 left turn signal out? Samson Tech & Performance Forum 18 25 Jul 2012 12:44 pm
