slight drag on passenger brake front
  • 1 Post By chuzz
Old 01 Nov 2018, 10:44 pm
Default slight drag on passenger brake front
ive got a 2003 pt 4 door. the thing is from new york. ive had to to alot of work that i did not expect to because the rust. the most recent is the passenger brake hangs up some. not enough to lock up or catch fire but enough to get rotor hot and have a slight pull to passenger side. i noticed that when i turn off max trac, it seems to not be there. now ive put new pads and rotors and lubed the slide pins. ive also removed alot of rust from caliper and spindle. ive changed brake fluid and it seemed to come out easy. now ive noticed that the abs ring on axle has alot of rust. so much so that there is hardly any space between the teet on hte ring could that be causing the computer to keep residual pressure on line and causing this? the piston in the caliper seemed to move with ease and so did the caliper on the sliding pins . the other possibility is collapsed rubber hose
Old 02 Nov 2018, 02:50 am
Default Re: slight drag on passenger brake front
I'd jack up the pass. tire and rotate the tire. There should be minimum drag. Have somebody push on the brake pedal ---- and release. There still should be minimum drag. If not, crack the bleeder screw. If the tire still drags, change the caliper. I'd change both calipers as they seem to fail shortly after replacing the pads up here in the north country.
Old 02 Nov 2018, 08:23 am
It could also be a failing rubber brake hose. I'd change both sides if it were mine.
Handy_Cruiser likes this.
Old 02 Nov 2018, 11:09 am
Make sure the pads slide easily in the bracket they rest in. I've had to grind to fit most of the one I've purchased. And lube the ends of the pads where they hit metal.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 02 Nov 2018, 04:12 pm
Handy_Cruiser's Avatar
+1
This is the most common reason for what you are experiencing.
Old 03 Nov 2018, 01:15 am
Macgyverman1123's Avatar
Mine was dragging and eating up the inside of the rotor from uneven pad wear. Wound up being a combination of a bad hose and the caliper was stuck shut. I was able to free it, clean it up and lubricate it with silicone paste and copper anti seize. Keep in mind, once you find the source of the problem, you will need to do a full front brake job. But don't let that dissuade you! Pray it isn't the ABS solenoid.
SLIGHT SHIMMY IN FRONT AFTER LOWERING? Jdhaulr1 Turbo Wheels/Suspension/Handling 7 02 Jun 2017 08:38 pm
Help please! Passenger front front seat back rest wobbly Feld PT Cruiser Videos 1 24 Mar 2015 01:41 am
WTB: 01-05 passenger front fender & front bumper cover g60racer Classifieds: Want To Buy 2 16 May 2013 04:39 pm
Passenger Brake Light SoccerMomMagnet General PT Cruiser Discussions 4 18 Dec 2011 09:45 pm
Slight front end bump AndyJay General PT Cruiser Discussions 2 18 Oct 2011 09:31 am
