A/C not cold at idle ?
Like Tree5Likes
  • 2 Post By ptcruisersteve
  • 1 Post By Macgyverman1123
  • 2 Post By chuzz
Old 05 Nov 2018, 04:19 pm
ZPT ZPT is offline
Default A/C not cold at idle ?
2007 , 2.4 Is the A/C supposed to blow refrigerated air at idle ?
It blows ice cold when driving at normal speeds , seems to just shut off the cold at idle , still blows air , but it gets warmer to ambient temp fairly quickly .
Thanks for your thoughts
Old 05 Nov 2018, 05:02 pm
Default Re: A/C not cold at idle ?
I would suggest checking to see if your radiator fan is working properly.
Engine light on? If so what codes?
LionPT and rsrocket1 like this.
Old 05 Nov 2018, 05:59 pm
rsrocket1's Avatar
...and keep an eye on the coolant temperature especially at a stop after getting off the highway. The fan should turn on at around 206F.
When you turn on the A/C, the fan should run at high speed all the time. This is easy to check when parked with the engine running and the A/C on. It sounds and feels like a small hurricane blowing around in the engine compartment when you lift the hood.
Old 05 Nov 2018, 06:42 pm
Macgyverman1123's Avatar
Sounds like you might have gotten the Curse of the Radiator Fan. Ask me all about it *sigh*
Sinbad likes this.
Old 06 Nov 2018, 04:39 pm
ZPT ZPT is offline
Thanks for your suggestions , you are all correct , I just checked the car and the fan is not working .
I don't understand the "codes" reference.
So is it likely to be a relay issue or fan dead thing , what is most common.
And how do I test that??
Regards
Old 06 Nov 2018, 05:49 pm
ajhockey3's Avatar
Usually its the fan, and new fans usually come with new relays, you can disconnect the wiring and hookup a multimeter to it and see if it is receiving power. Or connect the fan to power directly to see if it spins. Fan issues are very common on this car. Sometimes fan issues trip a code, whenever I have had fan issues it does not.
2006 PT Cruiser Base 2.4L NA $250
Old 07 Nov 2018, 08:10 am
Check the plug first. Sometimes they overheat and get burned. As for codes, the referrals are about retrieving the engine codes indicated by the check engine light. You have what is called an OBDII port under the dash. A code scanner is plugged into it and it scans the cars performance. If something is wrong, it will show up as a number preceded by a P. For example, a PO303 would indicate a misfire on cylinder #3. Just do a google search on how to retrieve engine codes for your PT. You'll find it.
Old 09 Nov 2018, 01:42 am
ZPT ZPT is offline
OK , thanks , I will test the fan , tomorrow when it stops bucketing down with rain .
If I need a fan assy , is this what I am looking for?
https://www.buyautoparts.com/buynow/...ly/19-20139_AN
Old 09 Nov 2018, 11:54 am
I am surprised that the radiator fan does not come with new radiator fan relays.
Rough idle at cold startup and PO302 Stretch Tech & Performance Forum 17 19 Jan 2018 05:25 pm
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
2002 pt cruiser rough idle when cold and 0303 code gordon2418 Tech & Performance Forum 7 15 Jun 2013 02:59 am
Miss at idle when starting cold?? mjb457 Tech & Performance Forum 1 14 Jun 2007 09:46 am
Fast idle in cold weather? katydidindeed Tech & Performance Forum 1 06 Jan 2002 08:07 am
