Sway bar bushing
Old 07 Nov 2018, 10:57 am
ajhockey3's Avatar
Default Sway bar bushing
so when I did my control arms, I am pretty sure I didn't put the way bar bushings back right, or in the right order, it clunks over bumps a lot, so I figured may as well get new bushings and put it in. Any recommendations? will be ordering from rock auto, the most expensive kit from energy suspension is only $20, should I just get that?
2006 PT Cruiser Base 2.4L NA $250
Old 07 Nov 2018, 01:55 pm
Default Re: Sway bar bushing
The Moog bushings have worked well for me. The slit in the bushing should face forward. Be sure to measure your sway bar diameter as the bushings come in various sizes based on sway bar diameter. They are 24 mm on my PT but yours may be different. Some anti-seize compound on the clamp bolts may be a good idea otherwise they will get rusty from all the winter salt spray and be a PITA to remove in the future.
Old 07 Nov 2018, 03:53 pm
VsandFords's Avatar
The Energy Suspension kit will have urethane bushings. The normal kits, regardless of the brand, will have rubber bushings. On a regular driver, the rubber bushings are fine, IMO.
If your set on urethane, GO FOR IT! It's only a few dollars more.
Old 07 Nov 2018, 04:26 pm
Just get the polyurethane kit for your diameter sway bar and make sure to replace the end links while your at it. I've had issues snapping my end links and having the sway bar clunk but I've also had a lot of issues with my LCA bushings as well, check both even if you just replaced your control arms.
Old 07 Nov 2018, 08:31 pm
ajhockey3's Avatar
Should have clarified, Im just doing the end links are they clunk horribly, the bar bushings seem to be fine
Old 08 Nov 2018, 07:58 am
I'd recommend doing the sway bar bushings at the same time, AJ. You're going to be under the car anyway and it doesn't take that much longer. That way, it's all fresh and you SHOULDN'T have to eff with it for quite a while after that.
Hey, hey I wanna be a rock star.
Old 08 Nov 2018, 11:14 am
ajhockey3's Avatar
Fair enough and they are cheap enough, Is there anyway to tell what size bushing you need without removing the bar and measuring it? Can you decode from the VIN? Would not like to get under my car if I don't have to, its getting cold
Old 08 Nov 2018, 03:51 pm
You do not need to remove the sway bar to measure it nor do you have to get under the car. Just reach in from the side with a caliper calibrated in mm and get a quick measurement.
Old 08 Nov 2018, 04:27 pm
rcktpwrd's Avatar
Cool Re: Sway bar bushing
or use some open end wrenches and slide them over the bar until one just goes over it, somewhere around 24mm...
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS
www.rcktpwrd.com
Old 08 Nov 2018, 04:43 pm
ajhockey3's Avatar
Cool, will turn the wheel and do that, Any reason why there is 3 sizes of sway bars?
Rear sway bar bushing pjvr Wheels, Tires, Suspension 13 27 May 2016 06:06 pm
Tie rods End, sway bars link, Sway Bars front and rear Pippov Turbo Wheels/Suspension/Handling 31 12 Feb 2016 01:54 pm
Control arms and sway bar bushing replacements AylmerQc Turbo Wheels/Suspension/Handling 5 11 Nov 2012 10:09 am
Bushing kit dadjmon Wheels, Tires, Suspension 7 23 Jul 2011 07:06 am
Sway bar bushing recommendations discovering06 Wheels, Tires, Suspension 2 01 Jan 2011 09:13 am
