Need Help Identifying
Like Tree4Likes
Old 10 Nov 2018, 01:19 pm
Default Need Help Identifying
So, I took off from stop and by CV AXLE broke on the driver side. After further inspection at home, I see the bolts holding up the transmission snapped and made the cv axle go on the frame. Since the bolts snapped, I need the part that is on the transmission and I canít find it anywhere. Please help.
Old 10 Nov 2018, 01:37 pm
Default Re: Need Help Identifying
Looks as if you lost the bolts out of your transmission mount
Old 10 Nov 2018, 02:11 pm
That part is quite expensive new. You can find this part easily in the junkyard.
Anyway the part number is: 4668628ab
https://www.tascaparts.com/oem-parts...port-4668628ab
Handy_Cruiser likes this.
Old 10 Nov 2018, 02:30 pm
Thank you. Wow yeah. I wish someone here was able to get the broken bolts out, but think I have no luck. I guess the next question is where do I find the replacement bolts?
Old 10 Nov 2018, 03:54 pm
I found the part on mopar a bit cheaper. Think it was on sale. Called them up to to find the bolts. They had those too. I hope nothing bad happened to the transmission. Only way I can find out is to fix everything.
Old 10 Nov 2018, 04:28 pm
Are you sure you need tha or number 8 in the parts photo
Old 10 Nov 2018, 06:29 pm
Itís definitely that part because I pulled it out to compare. I will probably need the number 8 picture later, but I can get that one locally. The bolts broke off in the one pictured above.
Old 11 Nov 2018, 02:08 pm
I seem to have found another problem when the engine sunk it also broke this hose. Been looking around and not sure what it is called because it has a plastic part with a nut on it.
Old 11 Nov 2018, 02:32 pm
Pcv vent to air cleaner hose
Old 11 Nov 2018, 02:44 pm
Thank you so much! Thatís the piece and looks like I can get it locally! Looked further at things and everything else appears to be ok. Will keep updates once the other parts come in near next weekend. Iím glad there is a forum for these cars. Youíre all awesome!
Help identifying this part.. Onephotostudio General PT Cruiser Discussions 6 17 Apr 2014 04:32 pm
Need Help Identifying Part BScott General PT Cruiser Discussions 4 09 Jan 2014 07:04 pm
Need HELP Identifying :( msmarvel General PT Cruiser Discussions 16 19 Sep 2011 04:01 pm
