Liftgate not working with key.
Like Tree5Likes
  • 1 Post By LionPT
  • 1 Post By ptcruisersteve
  • 3 Post By rckstein
Old 17 Nov 2018, 11:35 pm
Default Liftgate not working with key.
I have a 2006 pt cruiser that doesn't have the button under the latch. The remote key use to unlock the trunk. All of sudden that stopped one day. I open the back by inserting my key and holding the key while I open the door. It was suggested to me to get a rear hatch sensor at Napa but they said they didn't sell that or know what I was talking about.
Old 18 Nov 2018, 12:22 am
LionPT's Avatar
Default Re: Liftgate not working with key.
You can install a bypass switch, a lot of us have already done it.
Reasons Why Mopar is King: 2005 PT Cruiser
rckstein likes this.
Old 18 Nov 2018, 12:40 am
2010 Rear Hatch Release Button Problems
Old 19 Nov 2018, 12:59 pm
I don't have a hatch release button on mine. It's just suppose to open with the key button but that stopped working so now I have to use the key manually to open the hatch door. I have a keyhole instead of the hatch release button.
Old 19 Nov 2018, 01:41 pm
rckstein's Avatar
When you did use the remote to open the door, after you pressed the remote button to unlock the rear hatch, would you then reach under the winged emblem on the rear hatch and pull on the hatch and it would open?
If so, you may not think that there is a "button" under there, but there actually is and that is what triggers the rear hatch latch mechanism to unlatch and you can then open the hatch.
If you reach under the handle assembly, run your fingers along the surface on the back of the wings (not on the car side). You should feel a slight "bump" in the plastic. That's the touchpad switch that triggers the latch assembly to open the hatch. That switch can go bad and therefore does not send the signal to the latch assembly to open.
You can then refer to the other threads about installing a different switch to take the place of the failed switch.
dougs, ShinerJohn and the3dgm like this.
Old 16 Jun 2019, 11:48 am
dougs's Avatar
After 11 years and 96,000 miles, the squeezy plastic electro-switch under the liftgate emblem on my 2008 is beginning to fail. I wonder if the junior Chrysler engineer who designed this did an MTBF analysis. Fortunately, my 2008, built in 9/2007, still has a key, so I can open the liftgate manually....
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
Liftgate thecabinguy General PT Cruiser Discussions 4 27 Mar 2017 10:01 pm
Liftgate thecabinguy General PT Cruiser Discussions 0 27 Mar 2017 12:22 pm
Liftgate Badges kaameleon Classifieds: Want To Buy 2 04 Oct 2014 09:57 am
Liftgate Ajar Wishbone Tech & Performance Forum 6 05 Feb 2011 01:44 pm
liftgate frances General PT Cruiser Discussions 1 25 Jun 2004 12:26 pm
