Cruiser is Posesses
Like Tree6Likes
  • 2 Post By Handy_Cruiser
  • 2 Post By Wagondog
Old 30 Nov 2018, 09:51 pm
Default Cruiser is Posesses
My 08 Street Cruiser is doing some weird stuff, all in the last 2 days
1. Twice the car lost power when accelerating for a moment, when that happened all the warning lights came on for a second or two then went off. Then everything was normal.
2. I turned the heater on, the air coming out of the vents was just barely warm for an hour or so of driving then is suddenly began to work properly.....today my keyfob locking didn’t work, neither did the electric lock switch on the door. Five minutes later the fob and switch worked normally.
Do I have a devil.... or
Old 30 Nov 2018, 10:19 pm
Handy_Cruiser's Avatar
Default Re: Cruiser is Posesses
Often when this kind of thing happens it's due to a weak battery. In this scenario, the battery isn't dead but it let's the voltage dip down below 12 volts and weird things start happening. You should likely take the battery to a parts store like Auto Zone or Advance and let them charge your battery and then test it for free.
podo2000 and ptprice like this.
Old 01 Dec 2018, 12:22 am
Sinbad's Avatar
2. I turned the heater on, the air coming out of the vents was just barely warm for an hour or so of driving then is suddenly began to work properly.....today my keyfob locking didnít work, neither did the electric lock switch on the door. Five minutes later the fob and switch worked normally.
Clean and remake ALL the major earth connections between the frame and the engine. Give the cables a good pulling around to make sure they are sound. Clean and remake the battery connections. Then get the battery checked over as Handy suggests. You've then covered all the bases.
I'll put my money on a connection. A battery can crap out on you, but they don't often re-vitalise themselves on you.
_________________________________________
'07 2.2 CRD
Old 01 Dec 2018, 06:34 am
Thank you my friends for the advice, Iím not a car guy but battery or cables would have been my guess.
Thanks for the help and Iíll let you know how it goes
Handy_Cruiser and Sinbad like this.
Old 01 Dec 2018, 11:01 am
rsrocket1's Avatar
Also make sure you have nothing (or almost nothing) on the key ring with the key when it is in the ignition. The key switch bracket is a known point of failure and a heavy weight on the switch can cause the blink out of all the instrument lights followed by all lights lighting up again.
Old 01 Dec 2018, 11:13 am
As for the heater issue, when's the last time you checked your antifreeze level? You may need to add some.
Old 01 Dec 2018, 05:50 pm
Thanks for all the help, found the loose connection on the motor block. Hasnít happened again. Iíll lookbat the antifreeze as suggested.
You guys know your Cruisers. THANKS
Fk5 and Sinbad like this.
