Power Steering Leak
Like Tree2Likes
  • 1 Post By VsandFords
  • 1 Post By MJKnight
Old 10 Dec 2018, 01:22 pm
Default Power Steering Leak
Got a pretty bad leak from PS. It seems to be coming out of the pump, but I want to make sure that I'm not missing anything else to try before I in there and replace it.
Also, any tips about the replacement procedure are welcome!
Old 10 Dec 2018, 01:36 pm
VsandFords's Avatar
Default Re: Power Steering Leak
Lift it up and pull the splash shield so you can see the bottom of the pump. It's possible it is only the pressure hose.
When I replaced the pump on my 01, I pulled the bumper and right headlight for easier access.
This is showing the tools I was using to loosen the nut on the pressure hose.
Cut this line wrench to make it short enough to fit in the space.
Overall, not a terrible job. IMO
rsrocket1 likes this.
Old 12 Dec 2018, 12:51 pm
MJKnight's Avatar
You can pull the wheel ,slash shield..
Tensioner pulley to access the hose fitting...
With a crows foot and wobble extension
Old 13 Dec 2018, 02:14 pm
I noticed this morning that it was overflowing frothy PSF from the reservoir... does that indicate anything to you guys?
Thank you for tips.
Old 13 Dec 2018, 03:38 pm
MJKnight's Avatar
Getting air..
Busted_PT likes this.
Old 15 Dec 2018, 11:48 am
So basically, there's a leak somewhere... and that we already knew
Old 15 Dec 2018, 08:00 pm
MJKnight's Avatar
I would try tighten up the line on the bottom of pump..
I just replaced the high pressure hose on mine..
And replaced the power steering fluid with
ATF+4..
power steering leak creativelyinsanenotcrazy Tech & Performance Forum 1 14 Jul 2014 12:30 pm
Power steering leak oliverav Tech & Performance Forum 12 07 Apr 2013 09:46 pm
Power steering leak brandenfwee Tech & Performance Forum 5 25 Dec 2011 01:50 pm
Power Steering Leak (help) mjb457 Tech & Performance Forum 3 13 Jun 2011 05:46 am
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
